Stock Minime+Boost. I am doing it! Advice Please
Old Jun 24, 2012 | 10:42 AM
Honda4life777's Avatar
Icon2 Stock Minime+Boost. I am doing it! Advice Please
Good day guys,
I bought a 99 civic with a z6/y7/s40 swap. I have all new parts I need to boost it. I am not upgrading the internals, I want to see what kind of power I can get with stock engine. Not sure how much CP changed with y7 block. I am going to tune it for 10psi, just enough so i don't have to change my map sensor. Setting psi to 6 and go up slowly. Probably tune for E85 fuel if it lasts awhile. Here's what I got...
stock head/block... I think (previous owner just swapped, so i assume gaskets and belt have been replaced)
t3t4oe 50trim .63 a/r garrett turbo
cast manifold
2.5" dp/ cat then straight 2.5" exhaust to a big can muffler
tial 38mm WG (5psi spring)
BOV
intercooler, 2.5" piping
walbro 255
ngk plugs
440 delphi high injectors
LC-1 wideband
manual boost controller, gauge
p28 chipped with crome pro, ostrich emulator and data logger
New clutch kit for 250hp power
So that's whats lying in my garage, some installed, just waiting for the clutch kit to arrive before i can move on and finish.
Once together and running, I usually take whatever i am trying to street tune across the street in a big parking and have some fun. Then off to the dyno.
If you have any knowledge and or experience (build, tune, DO'S and DO NOT'S) with what i am about to do please clue me in. I am use to boosting b16's, not sohc minime swaps. Hopefully I can get 225whp for more than a week.
Old Jun 24, 2012 | 10:48 AM
Hidenplanvew's Avatar
Default Re: Stock Minime+Boost. I am doing it! Advice Please
220 is about as far as you want to push a d series motor I wouldn't assume anything in this game
Old Jun 24, 2012 | 12:35 PM
slayer423's Avatar
yea this dudes right and u better hope your gasoline is top notch 91 or your not gonna last very long. 220whp in a d series civic is a very fun car and should be pretty competitive among normal everyday cars but if your trying to make crazier power to keep up or beat exotics then i would definitely consider a b swap or k swap turbo
Old Jun 24, 2012 | 12:39 PM
slayer423's Avatar
Originally Posted by Honda4life777
Good day guys,
cast manifold
BOV
walbro 255
ngk plugs
LC-1 wideband
not sure on wat compression your running but retard timing under boost by .75 degrees up to 4, and then retard 1 degree after that to about 14 psi, then retard by 1.2 degrees to be safe. keep your air fuel ratio in the low 11s after 5000rpm and odnt be afraid to be in high 10s on the higher rpms(s2ks have a WOT air fuel ration of 10.1 which is super rich and those dont blow up so you should be fine) if you have crappy fuel to keep your egts down since im guessing your on stock internals.
Old Jun 24, 2012 | 12:41 PM
slayer423's Avatar
but if your motor can handle it just retard .75 degrees per pound across the whole boost table, and keep air fuel ratio under full throttle in the 13s below 4500rpm then have it start diping and have it float in the 12.0 to 11.7 range thru redline. this should generate the most power and look at your spark plugs after a couple pulls
Old Jun 24, 2012 | 01:34 PM
bluedragon's Avatar
If your internals are stock your probably only get maybe. 180-200 max if your compresion is stock don't push it or BOOM.
Old Jun 24, 2012 | 02:10 PM
wantboost's Avatar
Who is Mr Robot?
we have 93 on the east coast :p
but yea 220 is about as far as a stock d series will go before connecting rods start turning into projectiles
Old Jun 24, 2012 | 02:12 PM
grumblemarc's Avatar
The Grumpiest
Don't see why you'd need E85.
Old Jun 24, 2012 | 02:14 PM
wantboost's Avatar
Who is Mr Robot?
he wouldnt... not on that setup... he cant even reach the limits of 93 so its not like e85 is gonna be some witchcraft that allows you to make more than 220... plus its gonna require an assload of injector, more than 440s
Old Jun 27, 2012 | 07:09 AM
I was thinking e85 because it keeps your engine running much cooler and less of a chance for detonation. Plus I have everything to do it. May as well give it a try. And I don't really want to go past 225whp. But if the motor goes, then i will prob rebuild and go for 350hp. This civic in now become my hobby/ project car. Thanks for the advice on timing and afr under boost. They seem a little overkill ( retard per pound) but its defiantly on the safe side. I will start out my tune as you suggested (.75/lb to1.0/after 4psi) I have 93 oct across the street.
Old Jun 27, 2012 | 08:26 AM
The Grumpiest
That's what a good tune is for.
Old Jun 27, 2012 | 08:49 AM
wantboost's Avatar
Who is Mr Robot?
At 225hp you aren't even near the remote possibility of have detonation. And e85 keeps your motor cooler because it requires quite a bit more fuel compared to say 93. So not only are you not seeing any benefit from running e85 but you're getting worse fuel mileage which means wasting more.money every time you drive the car.
And Im tying to tell you, you run that motor at 225+ fwhp and you're driving a rod throwing time bomb
Old Oct 22, 2012 | 06:58 PM
Well, Months later after breaking, buying parts and fixing oil leak issues i finally got her boosted. Put in a good street tune (rich with a step timing retard per boost) with crome pro and I cant believe how good it is running. When the turbo spools the rpms top out within seconds. I picked the best sounding bov I ever heard, fluttering (like the whistling nerf football). In two weeks I will be taking it to MAPerformance (who helped me with oil leak) in MN to get her tuned with E85. I had my Integra beating ws-6 trans ams 7 years ago, and this little car pulls almost as hard as my integra. Any questions you have, i will happily tell you what i have went through.
Old Oct 22, 2012 | 07:00 PM
Oh yea I have adjusted the boost from spring rate 5psi to 7psi.
em1_civicsi
May 14, 2009 03:08 PM
petergriffen
May 23, 2007 05:12 AM
Schister66
Jul 21, 2006 04:26 PM
Wo-Nelly
Feb 24, 2005 10:28 AM
swlabhot
Mar 31, 2003 08:01 AM
