Broken wastegate bolt in cast iron manifold, fubar'ed?
Old Jun 21, 2012 | 12:01 PM
TravisBiggie's Avatar
Default Broken wastegate bolt in cast iron manifold, fubar'ed?
What a downer.. If i can't get this mother ****er out, no dyno tune for me tomorrow >< I've already inquiried about another turbo manifold on craigslist incase this fails.
I thought about putting something in the hole, and putting loctite in there, let it set, then try to screw it out. There is no access from the bottom of the bolt hole.
Any help appreciated!
Inb4 get a better manifold, I know, I know, I know!! I regret not using anti seize, and reusing shitty bolts ><
Old Jun 21, 2012 | 12:05 PM
RACEPAK's Avatar
Default Re: Broken wastegate bolt in cast iron manifold, fubar'ed?
you need to center drill it and then get a ez-out or a reverse drill might cetch it and pull it out,
Old Jun 21, 2012 | 12:06 PM
rich7777's Avatar
Just drill it out and use a longer bolt with a nut to fit the wastegate. I've had the exact same thing happen to me in the past and this is what I did.
Edit, that's if you can't do the above.
Old Jun 21, 2012 | 12:33 PM
Dc4LsTeG's Avatar
EK9
Try a left handed drill bit
Old Jun 21, 2012 | 12:50 PM
EsotericImage's Avatar
Retired Moderator
Shoot it with some PB Blaster and let sit overnite before doing the above steps.
Old Jun 21, 2012 | 01:26 PM
turbohatch96y7's Avatar
^^ exactly what I was going to say.. pb blaster is the **** for stubborn bolts.. if you don't have a drill take it to a machine shop should be like a 20 dollar job.
Old Jun 21, 2012 | 01:28 PM
Dc4LsTeG's Avatar
EK9
Just block off the wastegate hole and take it to the dyno
Old Jun 21, 2012 | 03:20 PM
Retired Moderator
that made me lawl
Old Jun 21, 2012 | 04:00 PM
Gunmetal_B20_Hatch's Avatar
"like"
Old Jun 21, 2012 | 07:01 PM
THIS! removed the bolt. Thanks!!! and thanks to all the replies
Good thing I bought this pos 20$ drill from harbor freight, first time I put it to use since I bought it 6 months ago
Old Jun 21, 2012 | 10:26 PM
Dc4LsTeG's Avatar
EK9
Damn and out of my two suggestions that's not the one I wanted you to try
Glad you got it out
Old Jun 21, 2012 | 10:50 PM
I guess the jokes on me
Old Jun 22, 2012 | 05:24 AM
wantboost's Avatar
Who is Mr Robot?
since the wastegate flange is cast into the top of the manifold, this won't work... unless you want a nut sitting inside a manifold runner, just waiting to vibrate loose and grenade a turbine wheel
Old Jun 22, 2012 | 05:31 AM
rich7777's Avatar
Yeah, your right lol. I can see the picture property now. I have a mini ram so you can picture how it worked for me.
I thought it was one of those eBay stainless manifolds...
Old Jun 22, 2012 | 09:05 AM
skateboard_ej8's Avatar
im hench irl
wow hah this happened to me not to long ago, about 100 miles from home. This is the only reason i dislike this manifold. That bolt will always be snapping off. It is in direct path of the exhaust.
Old Jun 23, 2012 | 01:30 AM
wantboost's Avatar
Who is Mr Robot?
its only gonna break if you don't use anti-seize, since the bolt will work harden to the threads.
theauthor17
Aug 8, 2008 11:47 AM
Nisif
Jul 16, 2007 07:48 PM
justinCO
Jan 17, 2003 07:46 PM
IntegD
Nov 18, 2002 12:17 PM
servion
Jan 15, 2002 12:14 PM
