I got CELs
Old Oct 14, 2002 | 01:35 PM
M.A.R.C.'s Avatar
Default I got CELs
Well one week into boosting. I got two CELs w/ the afc hack the yesterday. Code 13 (BARO sensor) and Code 45 (too lean/to rich... i'm thinking too rich). I got it w/ the afc set at -35 across the board so i tried -40 across the board today but i got another cel. Not sure if it's those same codes but it came on durign boost just like the previous ones. I'm not sure if these is a possible factors but a) my throttle plate is off (it's bent) or the fact that my injectors might not be all the way in because i snapped one of the fuel rail bolts (it doesn't leak fuel nor can i hear or feel any vacuum leaks). Just wondering if anyone else has ever got those codes while in boost.
setup is:
2000 civic ex, t3 turbo
afc hack w/ dsm 450cc's
Old Oct 14, 2002 | 01:38 PM
b18bturbo's Avatar
Default Re: I got CELs (CivicRyda2k)
make sure you wired the afc all correctly. I had problems way back when the fields controller similar to the AFC hack and it does same thign but if not wired and proerply soldering it gives some strange codes. mostly 13. RESET the ecu and check connection should be -40-45%
Old Oct 14, 2002 | 01:44 PM
M.A.R.C.'s Avatar
Default Re: I got CELs (b18bturbo)
yah I was thinking that too. I'm gonna double check everything when I have time this weekend. School is kicking my *** for now. Thanks Viren. Any other thoughts are welcome
Old Oct 14, 2002 | 02:29 PM
FredoSP's Avatar
Ugh CEL 13, I just posted something with that ... I got a good article from ClubSi's Boost Forum for CEL 13 -if you would like it. Most poeple with the GReddy Blue Box get 13. I see from your setup you dont have the blue box (your lucky). If you want more just let me know.
Old Oct 14, 2002 | 03:48 PM
shadowdawn's Avatar
You know what this stupid code 13 has been plagueing me forever.... anytime you have had this instance does it go on when going up hill with little load and light throttle, cause thats the ONLY time mine comes on for that...
Anyway I will take your advice and check the connections again, I would LOVE to get this CEL....
b18b please share any and all experience as to during what time this code happened in your cases if you can.
Old Oct 15, 2002 | 02:39 AM
M.A.R.C.'s Avatar
Default Re: I got CELs (FredoSP)
sure. PM me the link please.
Old Oct 15, 2002 | 02:41 AM
M.A.R.C.'s Avatar
Default Re: I got CELs (shadowdawn)
mine came on just under boost. like yesterday. i was getting onto the highway and i got on it a little... threw a CEL (like i said, not sure if it's 13 right now)
Old Oct 15, 2002 | 09:11 PM
M.A.R.C.'s Avatar
ttt
Old Oct 16, 2002 | 04:52 AM
FredoSP's Avatar
Here you go....
http://forums.clubsi.com/showflat.ph...r&Main=1248491
Old Oct 16, 2002 | 06:50 AM
Hellz99si's Avatar
Yeh man.....I just posted about this....wish I could fix it but no matter what it won't go away...maybe I just need to get hondata....unfortunately I don't know anywhere to get it tuned. Time to save up I guess.
Old Oct 16, 2002 | 07:27 AM
FredoSP's Avatar
Default Re: I got CELs (Hellz99si)
Im saving for Hondata too, I need a clutch First, ugh!!
Old Oct 16, 2002 | 08:07 AM
VaporTrail's Avatar
New User
I would keep your AFC settings at more like -38 - -35. Thats where I found them to work the best on your motor @ 9psi.
Old Oct 16, 2002 | 12:31 PM
M.A.R.C.'s Avatar
Default Re: I got CELs (VaporTrail)
cool i'll try leaving it there for a while until i drive my lazy (and broke) *** up to tampa to have you tune it.
Old Oct 16, 2002 | 01:26 PM
M.A.R.C.'s Avatar
Bumboclaat!!!
Old Oct 16, 2002 | 02:52 PM
filetofit
Guest
Posts: n/a
I wonder if you could crack open the ECU and solder a voltage divider onto the output of the baro pressure sensor so that the output would more closely match the AFC adjusted MAP sensor output. I've never really looked for the baro pressure sensor inside an ECU. Does anyone know if it's big and obvious and easily jerry rigged?
Actually now that I think about it that probably would **** up any baro pressure compensation that the ECU does. You'd have to find the specific circuit that does the comparison of the MAP pressure to baro pressure and tinker with that. Nevermind.
[Modified by filetofit, 12:00 AM 10/17/2002]
illicon2003
Jun 15, 2004 02:21 PM
jetpilot
Sep 4, 2003 08:37 PM
Starscream
Sep 3, 2003 10:05 PM
Tinker219
Mar 29, 2003 05:49 PM
Mr.DC2TurBo
Feb 14, 2003 09:59 PM
