Water Methanol Injection Questions?
Old May 8, 2012 | 02:00 AM
Dc4LsTeG's Avatar
EK9
Default Water Methanol Injection Questions?
So let me start off by saying I've searched and found little info on this when it comes to this being used on Hondas and I'd like to have one thread dedicated to the discussion of it in case anyone else is looking into it. I read through some of Calidads thread and found some good info but im sure I missed alot of it.
Id like to get some good info posted up from you guys that know about it, as I just started looking into the use of it and really want to use it on my build.
Some of my questions,
- Any cons to water meth injection besides costs?
- Wheres the best place to inject? Pre tb, pre turbo, intercooler?
- What % mix are you guys using? 50/50, 60/40, 70/30? And is that dependent on conditions/set up/preference?
- Are you guys mixing your own or buying premixed? If your mixing your own what are you using?
- What are some of the pros/cons of the different kits? I heard the Aem uses a progressive system, while others use an on/off approach?
- I take it the Aem kit is the best choice out there? (Ill be using Hondata S300v2)
- About how fast can I expect to go through 1gal. of mix on a 4-500hp B series?( I know this will depend on a couple different things, but about how much?).
- Is anything else recommended when adding this kit to your car?(part wise)
TIA
Old May 8, 2012 | 06:45 AM
non-VTEC's Avatar
Default Re: Water Methanol Injection Questions?
my cheap coolingmist.com kit is injecting directly out of the washer fluid bottle....yes.... windshield washer fluid with the smallest injector possible....most washer fluids come with a 50/50mix with some small trace of detergents which makes little to no difference to the mix. it works well..
you want to inject it pre t/b...a good 6-8" away from the throttle would be good. the AEM kit is quite good....but finding a place to mount the pump is a PITA....
the only con to the system is if the pump fails your tune will run a little leaner and it more prone to ping/knock. you need to run your tune overly rich so that it's not totally dependent on the injection kit to run safely. tune for about 11.5:1afr or slightly richer.
which reminds me....i need to go out and test my pump to make sure it's still working....hahaha....
good luck!
Old May 8, 2012 | 07:09 AM
KRITIK's Avatar
Learnt something today.
I believe i came across some info that says the AEM kit has a built in safe mode for wen ur fluid levels are getting low, and a boost over run safety mechanism
Old May 8, 2012 | 09:27 AM
Dc4LsTeG's Avatar
EK9
good luck!
Some good info thanks. As for the tune, I plan on having 2 different tunes, one street/pump gas and the other one track/ meth injection
Can anyone confirm?
Old May 8, 2012 | 09:44 AM
quick_ls's Avatar
I know this is K series, but it has a lot of good information throughout this thread.
http://forums.clubrsx.com/showthread.php?t=549019
I just finished installing mine. Running a 70/30 mix by weight. 96 fl oz of meth to 32 fl oz of distilled water. Its beind controlled through hondata on a nitrous switch, so basically 2 tunes.
Old May 8, 2012 | 10:16 AM
Dc4LsTeG's Avatar
EK9
I didnt click on it yet, but is it your build? Id like to know some more info on your setup since I want to run mine with 2 different tunes on my s300v2. Ill check that link out right now thanks
Please feel free guys to post pics of your setups also if you can. Pics of where you have it injecting and pics where you have the tank/pump mounted.
Old May 8, 2012 | 10:45 AM
Dc4LsTeG's Avatar
EK9
Just read through this, very informative thread thanks again
Anyone have any input on the snow performance kit vs. the Aem?
Old May 8, 2012 | 10:08 PM
EsotericImage's Avatar
Retired Moderator
http://www.turbomirage.com/water-alc...arts-list.html
Old May 8, 2012 | 10:56 PM
Dc4LsTeG's Avatar
EK9
Thanks for that. Cheap prices, any recommendations?
Old May 8, 2012 | 11:05 PM
Dc4LsTeG's Avatar
EK9
If I were to get the parts for that kit, which pump would I need. Also could I make this work the same way as an Aem kit works?
Old May 8, 2012 | 11:19 PM
Retired Moderator
youll need the AEM electrics which may or may not be sold thru aem
Old May 9, 2012 | 04:02 AM
Dc4LsTeG's Avatar
EK9
Not sure. Do you know exactly what electrics ill need? Ill look to see if Aem sells it seperate. If not ill prob just stick with getting the Aem kit
Old May 9, 2012 | 06:35 AM
KRITIK's Avatar
http://www.aemelectronics.com/water-...ction-kits-23/
Old May 9, 2012 | 11:08 AM
Dc4LsTeG's Avatar
EK9
Does the failsafe device come with the kit or do you have to buy it separate?
Old May 9, 2012 | 02:00 PM
Retired Moderator
Holy spoon feeding.. look it up man. If your confused, call AEM
Old May 9, 2012 | 02:04 PM
Dc4LsTeG's Avatar
EK9
I already looked it up thanks though. I was a little confused at first at what exactly it was
mitsuman
Aug 11, 2013 02:35 AM
-=TWITCH=-
Mar 11, 2004 07:04 AM
Kack
Sep 12, 2003 05:34 PM
blufke
Sep 29, 2002 02:49 PM
