Pre Turbo Water Injection
So i've been researching a bit on the topic, although am trying to get some additional info. How many of you guys use, have used, or plan to use water injection, more specifically pre turbo?
How do you like it? Any data sheets(i.e. IAT before and after, etc)? how does it affect the spool? long term effects?
thanks
thanks
Moderator
Re: Pre Turbo Water Injection
Unfortunately, few Honda people here utilize meth/water injection except for a few regions, because of the whole phenomenon of "E85 is better than p**sy, man!" So, what happens is you have those that use mainly a 550cc-615cc injector into the throttle body, and about 200-315cc for the inlet into the turbocharger.
Californiadad actually did a 4 X315cc direct-port style meth/water injection in his intake manifold. check his thread for specifics.
thanks for the info. what are your thoughts about pre turbo injection? do you have any experience with it first hand? there are many different opinions on water/meth vs wiper fluid vs pure water etc etc etc, and size nozzles. i know each different application will require different pressure/flow. but i have literally not seen any info on pre turbo injection on a honda
It's been done and the results were not publicly available. What I know is that it didn't work well on an all out drag car. It caused turbo rpm to drop to the point where it hindered perfromance. What happens is the large surface area on the blades caused the water to recombine into larger droplets. When you loose the atomization you lose the heat removal potential and can induce premature wear on the compressor wheel. This is even more of a problem on the billet wheels with grooves in the compressor wheel.
^ thanks for the info. i am not planning on pushing more then 300-350whp max with an evo 8 turbo. So that puts me in a much lower bracket. I guess i will have to just test things out.
heres a link i found with some results for those interested:
http://www.dsmtuners.com/forums/nitr...t-results.html
Moderator
A simple pre-throttle body 500cc injection nozzle is all you need. About 3-5" really, enough time for it to atomize. The other Evolution 8 we got is using a TR3030R with a single nozzle of 95% methanol 5% distilled water (simple yellow bottle HEET) for over 470AWHP so far on the stock 2.0 with GSC S2 camshafts and zeitronix wideband with a Cobb Access port. Very nice, easy, and stable. been done for years. Simple AEM kit.
When we tried the Pre-turbo option, similar results occurred with what Tepid1 described. Mainly because the turbocharger compressor just didn't see enough heat in the inlet itself to enable a good atomization process to occur, and it was almost like compressing water.
I say keep it simple, by single nozzle, or you can get a bit crazy with the direct port version if you must. But the pre-turbo wasn't worth it.
Oh. that's it? on an evolution? Ah, you should have said that from the beginning. I was thinking Honda related (due to the forum and all, who'd have guessed? )
so my curiosity stands, still no info on pre turbo on a civic haha. I am not looking at pushing 450 on pump gas, i am simply trying to maximize the efficiency of all of my components. from what i read(only read, no experience here on this topic) water/meth injection pre turbo helps the turbo act more efficiently, now if i inject post turbo, yes i will see lower temps, but would it be more beneficial to have the turbo acting more efficient? or simply having lower iat's?
Just focus on lower IAT's. Why would you want to take energy out of the turbo? As it is it takes energy to spin it so it's a double negative. You'll get better results post turbo. Like TheShodan said, keep it simple and keep it reliable.
Most of what I have seen has been theories and noting has ever come to being effective. I think the key is to keep the preturbo nozzle small and the pressure high (100psi+) so that it's a super fine mist. Also, forget about anything with water in it.... yes even 5% is too much. Straight alcohol/meth or even acetone would work great. For anyone who knows high grade race fuel knows acetone works like a dream!
Moderator
It's even stated in the article as a caveat.
"To do this properly requires proper sizing of the nozzles in relation to the compressor size and output. Additionally, the type fluid being used also effects the size of the water injection nozzle selected. When done properly, very little of the water methanol mist injected into the inlet of the compressor survives the process."
The author continues:
"When injecting water, we can quickly over saturate the air charge and have an excess of fluid discharging the compressor. Water has a much higher latent heat of vaporization, nearly double that of methanol, and does not flash (instantly evaporate) like that of methanol or other alcohols when injected into a hot air stream. Therefore, a smaller nozzle must be used when spraying pure water. "
Lastly:
"One major concern associated with pre-compressor injection is [physical] erosion of the impeller. This is only likely to occur when injecting solid stream of water at the impeller of a turbocharger or using an excessively large nozzle". This is from the higher speeds seen on turbocharger impellers than centrifugal or Rotrex superchargers.
I see it as making the turbo less efficient as you would essentially be slowing down the airflow/pressurization process on the compressor side of the turbo. Especially if only using this for "daily duty", I see more detriment than benefit based upon my experience and the article's interpretation. 1) You're not generating enough consistent heat in the compressor cover to create a constant flash point for the methanol, 2) more than likely you aren't using 100% methanol in the first place to where that flash point comes quickly enough. 3), you're not going for that kind of use and power, and the erosive effects will more than likely take over faster than a purpose-made car anyway.
Again, whether its a civic or an Evolution whatever, Keep it simple at the TB neck. And make sure you have the right distance so that it can atomize properly. Focus on lower IAT's and lower cylinder pressure temps in the combustion chamber. Leave the compressor wheel out of the equation
Who is Mr Robot?
The key is that the nozzle must be centered on the wheel or you'll have wheel erosion
The issue is you only inject enough to vaporize as it compresses which is what takes the heat away. You don't want it leaving the turbo in liquid form
When done properly you'll see a turbo outlet temp that's at ambient temp or below. Users have reported everything from condensation on the hot side piping and intercooler to having ice form on the intercooler
Aquamist makes a pre turbo injection nozzle holder that is ingeniously made, they've done extensive testing on this subject and have shown that with the nozzle centered in the inlet (aimed at the shaft center) and the proper fluid volume that no wheel erosion occurs and theres no liquid methanol/water leaving the turbo. It simply vaporizes when compressed
I'll be utilizing pre turbo meth injection on my build as well
thanks guys for the info. Can you look at this response by a member of another forum on the subject. He gets into some pretty technical terms, which i feel most of us are unaware of. can you pick it apart? theres also a pretty technical post after his...
http://www.aquamist.co.uk/vbulletin/...78&postcount=6
http://www.aquamist.co.uk/vbulletin/...read.php?t=251
Next, all that BS about making the turbo more efficient is just that. BS. Believe what you want, but a car in the 1/4 mile that goes 180mph on pre injection then goes 184 without and no other changes and same boost target is making more power. Period.
Who is Mr Robot?
Potential erosion is why I'm have the comp wheel hard anodized, same with the comp housing and like I've stated in other threads this is simply an experiment. I'll be monitoring a lot of factors and decide from there if it has a benefit
I still however am running "direct port meth/water injection" in every runner of my itbs. It's a good way to monitor how much or how little is needed. This also gives me equal distribution and the abilities to fine tune each jet in each cylinder, as well as overall system pressure
Like I said. Still experimental
Moderator
Moderator
But again, he, like the other author, warns the user
"By injecting water/alcohol ahead of the compressor two things happen. You cool the inlet air substantially, this in effect moves your true operating point to the left on the compressor map. (in most cases for max performance this is a good thing, although on some turbocharger conditions it can cause compressor surge.)"
Who is Mr Robot?
Here's a randkm idea that I just had
What about injecting into the compressor volute right as it starts after the wheel. It would still compress/vaporize slightly but at the same time lower compressor outlet temps without pontential wheel damage
Moderator
Try it if you want, my friend.. That's just too much for one purpose. It makes no sense at that point. that's like adding up 4 different bolt-on modifications that have an advertised HP ability and adding them all together. There's a net effect, but not in the way you think.
Who is Mr Robot?
True but I have seen a lot of successful pre turbo setups. The flow volume has to be precise as does atomization and line pressure, like 300psi minimum
I know a lot of compound diesel and large single diesel guys use pre turbo with no issues but they've somehow figured out how to generate 1000psi for their injection system
Moderator
Never said it doesn't work, only that you must be precise in that inlet location. Let's just agree to disagree at this point, as its getting redundant.
