Water Injection
Old Sep 12, 2003 | 02:18 PM
Kack's Avatar
Default Water Injection
So what do you guys put in your reservoir? Just water? I heard a 25% alcohol mixture is good since it evaporates well. If so what alcohol can you use? Rubbing alcohol from the store?
Old Sep 12, 2003 | 02:30 PM
Kack's Avatar
Default Re: Water Injection (Kack)
nother question, Bosch Platinum Plugs...use em or throw em away?
Old Sep 12, 2003 | 04:41 PM
Kack's Avatar
bumpers
Old Sep 12, 2003 | 05:34 PM
joeo's Avatar
I'm new here - but thinking about purchasing a GSR and turbocharging it. I currently have an MR2 and use water injection.
I've tried all distilled water, a 50/50 mix of water and denatured alcohol, and all alcohol. On my car, it already runs rich, and I get best results with straight water. If you are running somewhat lean a 50/50 mix is a good place to start. Methanol is probably best, but denatured is almost as good (and can be purchased at local hardware stores). Make sure the setup you are using (pump, seals etc) can handle the alcohol.
BTW - is there an FAQ about turbocharging Integras? Thanks!
93h2beg
Welding / Fabrication
Jan 13, 2018 06:31 PM
AudioFunk
Jul 14, 2014 01:15 PM
ekim952522000
Feb 11, 2007 11:41 AM
Jared
Aug 15, 2005 08:06 AM
Turbo00
Sep 13, 2001 11:06 PM
