ESP altenator bracket issue h2b eg hatch
This is why I am making my own. There is always the Bisimoto option to the tune of $130. I honestly would have somebody fab one up for you for that price. It would most likely be cheaper, cost less and you could have your car running in a day or two.
Or do what I did for my F2D swap. Drove with the battery and charged it when it was parked. GHETTO. Don't worry I am almost finished with the alt. bracket so I can DD mine too....
Just gotta figure out how to raise my hood about 4 inches to clear the IM.
Good luck.
Good luck.
I don't know about wrong bracket. Possibly made wrong? That looks way off. Perhaps an obd1 alternator will do the trick if you've got over chillin.
wow i was just about to order one of these for my crx but i was already leaning toward having one fabbed just cause i dont want to wait 6 long weeks too. If you dont mind me asking, what track bar are you running?? Because supposably the esp lower d bracket 1/2 over only works with esp ef track bar ...I run a k tuned track bar and i was told i MUST run the upper 1/2 over brackets due to the alt hitting the radius rod... ps i wonder if you can put maybe a washer or two behind that alt pulley and get it more toward proper alignment. i bet that would be a fun peice to remove
Definetly is off odd... I have had probably had less then 4 off alignment out of several hundred. Pretty good ratio if you ask me. Emailed you Kevin! Send back and will fix it or send out new one!
All D Alternator Kits are mocked off 88-91 Civic/Crx D alternator 3 ribbed belt and pulley. Didn't make sense to also have one for the 92+ Civic D Alternator (different far as mounting) that is 4 ribbed belt and pulley. Might as well use 1 with the biggest advantage, the 3 rib. OBD0 D Alternator also uses round plug same as OBD1 H22.
got my bracket back like in 2 days of them recieving it already bak on the car. had to switch over to the obd1 altenator however .bracket still look like it need more space for it to clear for obd0. but with obd1 it fit perfect.
It still wouldnt fit a obd0 3 rib alt .jeez that sux
yea i got my mechanic ruler 90 angle it was off by very little it might b because i have the spacer in front of the crank pully to keep my timing belt from sliding but with the obd1 it fit perfecto.. still got alot of clearance from the chasis tho
