turbo oil feed and return line?
Quick question, which oil feed and return lines should I use for a stock b16a turbo set up with around 6 psi of boost. Will the ebay ones work since its not high boost or is there somewhere else I should get them?
there was just a thread where the some guys 15.00 ebay fittings failed.
proper plumbing seeing up to 80 psi needs to be done right..
http://www.brfittings.com/index.php?...tegory&path=39
ok, then get the ebay stuff, then when it fails get the good ones. just pay for the same part twice.
I guess i need to remind you that with ebay, what you see isnt always what you get.
YOU GET WHAT YOU PAY FOR!
Don't cheap out on oil lines. I got a feed/return eBay kit for free and it still wasn't cheap enough. After less than 6 months the feed and the drain started leaking. Not a huge amount, but I usually had to add a quart between oil changes. My buddy also went through 4 eBay feed lines on his turbo LS, melted all of them in less than 500 miles.
