Oil line quick 2 questions
Hey all
Sorry for time wasting thread but I'll make it quick
I'm wondering would this oil line kit fit a gt35 wastegate version cheap ebay turbo
http://www.ebay.com.au/itm/141786896023?ru=http%3A%2F%2Fwww.ebay.com.au%2Fsch %2Fi.html%3FisNewKw%3D1%26isRefine%3Dtrue%26mfs%3D GOCLK%26acimp%3D0%26sqp%3D141786896023%26_nkw%3D14 1786896023%26_rdc%3D1
And also an4 as it says the feed line is.. will that fit in to a 1/8npt oil pressure t piece that I've got in the block
Thank you in advance only making thread to be sure
Re: Oil line quick 2 questions
it works, but not well. two major problems with this kit.
1. You never want to use brass fittings directly into an engine block, they break and can **** your engine, just saw a thread where a guy had this problem..
2. That feed flange in my opinion gives more variable to leaking, since it requires a gasket, I hated mine and will never use one again. You're better off buying just a fitting and directly installing it into your turbo oil feed hole (it should be 1/8 npt thread, standard)
2.
This kit doing research all day the feed is an4 which is the equivalent to 1/8 npt but adaptors are only $3 that I'll use one to go into the t piece and into the turbo eliminating the need to use that gasket leak prone flange
Also it says oil restrictior but no spec on size its 2mm i believe for journal bearing turbos i think
I think i might go with this kit just hope i can get a few thousand miles outta it at least
Any other problems you see in this set up ?
