Car Wont Pass 4k Rpms...
Old Feb 22, 2012 | 04:05 PM
OhGeeRize's Avatar
Icon2 Car Wont Pass 4k Rpms...
I was running low on gas this morning..
so i put some on the 87 octane
i usually pump only 91 octane(just cuz)
but ***** getting expensive
and since reading so much that the octane readings really didnt matter unless you tuned the car
i pumped 87
and now my car wont pass 4k rpms
feels like thats the rev limit
and i started throwing out a lil bit of white smoke from exhaust
i never had this problem till i pumped that gas
any ideas on what it can be?
thanks
B20v motor
b20b bottom end b16 head
stock internals
Old Feb 23, 2012 | 02:42 AM
7rrivera7's Avatar
Default Re: Car Wont Pass 4k Rpms...
Check engine light on? Sounds like the ECU is in "limp home mode" to me...
Old Feb 23, 2012 | 03:12 AM
4tika4's Avatar
is your speedometer working?
Old Feb 23, 2012 | 02:34 PM
OhGeeRize's Avatar
my check engine was on..
i check the code and it threw out code 10
thats the iat sensor
it was disconnected a while ago because the wire was too short for my intake
i got it connected again..reset ecu
it doesnt redline at 4k anymore
but it does feel like its bogging out once i try to press the gas pedal further down
speedometer is working but i notice it bounces a lil more than usual
ive had trouble with it in the past but all i did was connect back snug
ive leaning towards the dizzy or tps
since i am running a LS dizzy on my pr3 head
some shop ****ed me over by givin me an ls dizzy...im going to switch it sometime this week since i finally have the money to replace it
but i havent had any problems till i switched from 91 to 87 octane
Any other suggestions?
thanks btw
Old Feb 23, 2012 | 02:49 PM
7rrivera7's Avatar
The octane will affect the "feeling" of your engine. It may be detonating and if you wired in a knock sensor with an ECU that uses it, it may be pulling timing. Are you running a tuned ECU?
Old Feb 23, 2012 | 03:00 PM
OhGeeRize's Avatar
I feel as if the detonation in the combustion chamber is detonating on its own and not by the spark plugs..
im currently running a p28 chipped
i dont think p28s read knock sensors..or do they?
i think my LS had one tapped in there before so i used that one
not 100% sure tho
Old Feb 23, 2012 | 03:18 PM
OhGeeRize's Avatar
Just Went outside to look for a knock sensor
and yes i think ive got it...
correct me if im wrong
next to the alternator bracket by the oil filter is 2 sensors
i think 1 is the KS and the other is oil pressure?
Old Feb 24, 2012 | 01:18 PM
OhGeeRize's Avatar
Just an update
Through some octance booster in there and let it run for a little while
(So that the booster can sit thru the gas)
Drove it around and it feels great..
So I guess octane readings do really matter
Never pumping that ever again
Thanks for your help
Old Feb 24, 2012 | 04:12 PM
7rrivera7's Avatar
Good news - and no, the P28 does not support a knock sensor.
Old Feb 28, 2012 | 12:23 PM
Motox122jk's Avatar
P28 doesn't support KS? I'm assuming if you have some sort of engine management like s300 or Neptune that the knock sensor input is added in provided you have a knock sensor?
Old Feb 28, 2012 | 01:52 PM
7rrivera7's Avatar
P28's do no support a KS - period. For that you need a P30, P72 or PR3
Old Mar 4, 2012 | 11:50 PM
BobbyRodriguez's Avatar
Limp mode
OEMJDM
Honda Civic (2001 - 2005)
Sep 23, 2012 09:03 PM
soLaLive
Feb 15, 2010 04:57 PM
mister.wong
Jan 14, 2009 03:48 PM
Lucky-13
14
Mar 17, 2007 05:54 PM
adam
Nov 13, 2001 06:45 PM
