Turbonetics Deltagate Mark II opinions
I came across an older Deltagate Mark II wastegate in almost new condition. I picked it up for practically nothing. I have heard mixed issues with this particular model and was wondering pros and cons.
I soon realized that there are zero rebuild kits for this thing so I took it apart to check the internals and to my surprise..it is in extremely good shape. The diaphragm is perfect and everything is in tip-top shape. I plan to use it on my current build with the current (I think) 7 lb. Spring.
Should I use it or ditch it and buy a trial??
Any upgrades I can do to it to make it last longer under normal driving conditions? Any help, input, ideas would be greatly appreciated.
I had the old delta gate before and it did leak. So I put a compressor to it about 5 psi.
Found leaks from the screws that mount the diaphragm to the exhaust outlet. All I did was put gasket maker on the screws than I installed the screws and never had a problem. Leak test it
Creep is not from the gate it comes from your crappy manifold design... Wastegates are not the most technical thing on earth its a valve a spring and a housing... Make sure it holds pressure and your good.
I had a couple of them, worked great and had no problems. Like was said, a wastegate is a simple part. As long as it doesn't leak you'll be fine. You don't have to have the latest fad of the week on HT to have a reliable inexpensive setup.
