TiAL wastegate problem....
Old Jul 13, 2004 | 07:59 PM
crazyimport's Avatar
Default TiAL wastegate problem....
Ever since i bought my wastegate (used) its had a problem.. but no i think its effecting the boost.....
i can lift the top peice about a cm up and down ...... and when u can pull it up and hold it when the car is running, and it u can hear it leaking and exhaust coming out of the dump..... it should b doing this should it? it should b nice and tight...
is there a gasket or bushin i have to replace?
Old Jul 13, 2004 | 08:10 PM
B18C1CYA's Avatar
Default Re: TiAL wastegate problem.... (crazyimport)
hum it is not suposed to do that, well its already broke so i would take it apart and see whats going on inside, maybe something is loose or missing.
Old Jul 13, 2004 | 08:12 PM
Default Re: TiAL wastegate problem.... (B18C1CYA)
yah its weird.... i didnt really notice it today until my boost gauge was reading max 4.....
i have a 7 psi bar in there.. and i dont even hit 7... max 6
Old Jul 13, 2004 | 08:15 PM
B18C1CYA's Avatar
so was it ok ,and then started being strange?
Old Jul 14, 2004 | 01:19 AM
its always been loose.. but now its effecting my boost pressure...
Old Jul 14, 2004 | 02:17 AM
flip1199's Avatar
which part are u talking about? are u talkin about he part where the spring is?
Old Jul 14, 2004 | 04:14 AM
RacerXI's Avatar
Default Re: TiAL wastegate problem.... (flip1199)
When I picked up my tial, it did the same thing. If i'm correct here, his top machined (hat) is loose from the bottom (cast section). Take the 10-12 allen bolts off the top machined section of your tial. After that comes off, you'll find your WG spring. After the spring is out, there is another small part to pull off of your rod section (part spring sits on). Below that is a 19mm that you can tighten up to get rid of that excess play in your WG. HTH or at least makes sense.
Old Jul 14, 2004 | 09:34 AM
SiRkid's Avatar
dude, your tial is a pos..scary ****..
you can rotate it and ****..lol. yeah ive seen it
i would get a new one....
Old Jul 14, 2004 | 09:42 AM
zc911's Avatar
Default Re: TiAL wastegate problem.... (RacerXI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerXI &raquo;</TD></TR><TR><TD CLASS="quote">When I picked up my tial, it did the same thing. If i'm correct here, his top machined (hat) is loose from the bottom (cast section). Take the 10-12 allen bolts off the top machined section of your tial. After that comes off, you'll find your WG spring. After the spring is out, there is another small part to pull off of your rod section (part spring sits on). Below that is a 19mm that you can tighten up to get rid of that excess play in your WG. HTH or at least makes sense.</TD></TR></TABLE>
thats what you need to do
Old Jul 14, 2004 | 02:36 PM
thanx man ill try 2nite
Old Jul 14, 2004 | 06:08 PM
all tightened ..... thanx man...
bov is 500% louder now and seems to pull way harder...
i was hitting 10psi thou....
so i duno whts up with that
g2daturbo
Jun 2, 2008 03:45 AM
accordfreak
Mar 2, 2003 10:28 AM
DD_JonnyLee
Jan 7, 2003 08:17 PM
X2BOARD
May 30, 2002 10:09 AM
Lei Siew Long
May 12, 2002 05:43 PM
