car has spark fuel but no start
Old Nov 7, 2011 | 05:56 PM
nandito's Avatar
Default car has spark fuel but no start
I checked ecu and fuel pump wiring and car wont start it has spark
Old Nov 7, 2011 | 06:08 PM
Schister66's Avatar
Man U FTW
Default Re: car has spark fuel but no start
You only need a few things for your car to run:
-Spark
-Fuel
-Air
-Compression
What happened?
When did this occur?
Does the fuel pump prime?
Is the main relay working?
Have you checked fuses?
We need something more to go off...
Old Nov 8, 2011 | 06:37 PM
nandito's Avatar
main relay was out i switched it but stilll no start it has gas it has spark
Old Nov 9, 2011 | 10:07 AM
ddwelch's Avatar
If it has both spark and gas time to check compression.
Old Nov 9, 2011 | 10:22 AM
DirtyDA9's Avatar
How did you check to see if it is getting gas? Just because the fuel pump primes doesn't mean you are getting gas to the cylinders, check to make sure the injectors are actually working... And did you make sure you have spark in ALL cylinders...
Old Nov 9, 2011 | 10:36 AM
aveink's Avatar
yea first check for injector pulse by taking out on the the injector clips one wire will be positive and will be on with the ignition on and the other one is ground and ill pulsate when your cranking, if thats all good, its time to check you timing and make sure ur getting good compression
Old Nov 9, 2011 | 01:11 PM
nandito's Avatar
hahaha turned out my friend forgot to check the spark plug cable firing order even after we had tolled him to double check he said it was good turns out it wasnt
Old Nov 9, 2011 | 01:38 PM
DirtyDA9's Avatar
Lol that's why I do everything myself or double check stuff other people did. Never go off someones word when it comes to anything like that.
Old Nov 9, 2011 | 08:27 PM
nandito's Avatar
yeah i wont do that again
GsO Redneck
Sep 7, 2012 10:13 AM
xLaziestLa0b0ix
Mar 6, 2012 06:38 PM
Championship
Nov 25, 2010 05:36 PM
MrViet
Jan 4, 2010 07:58 AM
ToiletFetusSushi
Sep 30, 2004 09:12 AM
