car has spark fuel but no start
Old 11-07-2011, 05:56 PM
nandito's Avatar
Default car has spark fuel but no start
I checked ecu and fuel pump wiring and car wont start it has spark
Old 11-07-2011, 06:08 PM
Man U FTW
Schister66's Avatar
Default Re: car has spark fuel but no start
You only need a few things for your car to run:
-Spark
-Fuel
-Air
-Compression
What happened?
When did this occur?
Does the fuel pump prime?
Is the main relay working?
Have you checked fuses?
We need something more to go off...
Old 11-08-2011, 06:37 PM
nandito's Avatar
main relay was out i switched it but stilll no start it has gas it has spark
Old 11-09-2011, 10:07 AM
ddwelch's Avatar
If it has both spark and gas time to check compression.
Old 11-09-2011, 10:22 AM
DirtyDA9's Avatar
How did you check to see if it is getting gas? Just because the fuel pump primes doesn't mean you are getting gas to the cylinders, check to make sure the injectors are actually working... And did you make sure you have spark in ALL cylinders...
Old 11-09-2011, 10:36 AM
aveink's Avatar
yea first check for injector pulse by taking out on the the injector clips one wire will be positive and will be on with the ignition on and the other one is ground and ill pulsate when your cranking, if thats all good, its time to check you timing and make sure ur getting good compression
Old 11-09-2011, 01:11 PM
nandito's Avatar
hahaha turned out my friend forgot to check the spark plug cable firing order even after we had tolled him to double check he said it was good turns out it wasnt
Old 11-09-2011, 01:38 PM
DirtyDA9's Avatar
Lol that's why I do everything myself or double check stuff other people did. Never go off someones word when it comes to anything like that.
Old 11-09-2011, 08:27 PM
nandito's Avatar
yeah i wont do that again
GsO Redneck
09-07-2012 10:13 AM
xLaziestLa0b0ix
03-06-2012 06:38 PM
Championship
11-25-2010 05:36 PM
MrViet
01-04-2010 07:58 AM
ToiletFetusSushi
09-30-2004 09:12 AM
Quick Reply: car has spark fuel but no start
