My b18c5 Build
Old Oct 18, 2011 | 05:43 PM
Cyphen19824's Avatar
Default My b18c5 Build
Hey guys finally finalized my build and im sticking to it. going for around 450-500whp/ useing a GT3582r. Going to tune on E85/Q16. around 25-30lbs of boost. let me know what you guys think!
and for driving on streets 91 on low boost
B18C5:
Darton sleeves
Arias 8.5C/R 84mm pistons
Manly Turbo Tuff I-Beams
ACL bearings
Stock GSR Crank
ARP Head studs
Head is a B16A
FULL supertech valvetrain with 1mm Oversized valves w/ Black nitride valves
head is beings decked
ITR Cams
MSD Ignition system
Victor X Intake mani
BDL 70mm Throttle body
Cometic Head gasket
750cc injectors
Golden eagle fuel rail
Adjustable fuel pressure regulator
AEM adjustable cam gears
Trans
Wavetrac LSD.
Spec stg 5 clutch
Old Oct 18, 2011 | 06:42 PM
TheShodan's Avatar
Moderator
Default Re: My b18c5 Build
Originally Posted by Cyphen19824
Hey guys finally finalized my build and im sticking to it. going for around 450-500whp/ useing a GT3076r w/ P-Trim. Going to tune on E85/Q16. around 27-35lbs of boost. let me know what you guys think!
B18C5:
Darton sleeves
ACL bearings
Stock GSR Crank
ARP Head studs
Head is a B16A
ITR Cams
MSD Ignition system
Cometic Head gasket
750cc injectors
Trans
Wavetrac LSD.
Spec stg 5 clutch
GT3076R Never came in a P-trim exhaust wheel. NEVER. You couldn't even swap a P-trim turbine INTO a GT3076R cartridge. It would never fit.
Old Oct 18, 2011 | 06:50 PM
Turbo-LS's Avatar
Bump the compression up to mid 9's, otherwise its a good build for the hp, sleeves werent needed for that power level but its added security, dont be concerned with boost pressure and just obtain your HP goal which is doable with a gt3076r, but like shodan said not available in ptrim wheel, gt is a gt wheel
Old Oct 18, 2011 | 09:28 PM
Damn i thought p-trim would fit! meh! i should be easly able to obtain my HP goal with this build.
Old Oct 18, 2011 | 09:30 PM
Juan Doe's Avatar
bumppppppppp
Jason Buechler
Jul 29, 2014 04:38 PM
tics
Nov 2, 2007 07:48 AM
BlangBlangTEG-93'
Mar 5, 2007 08:23 AM
turbodan4
Feb 27, 2006 10:41 AM
ludesleep
May 30, 2003 02:54 AM
