wot do you guys think?is this a good setup?
Old Oct 31, 2007 | 11:01 AM
tics's Avatar
Default wot do you guys think?is this a good setup?
hi guys im from the u.k and i am currently in the middle of my boost build and just lookin for your opinions and help.wot do you think of this setup?
fully sleeved b18c4 block
wiseco low comp forged pistons
eagle rods
acl main bearings
cometic head gasket
standard head????
itr valvetrain maybe???
1.6 vti gearbox with lsd
cc fab turbo manifold
gt30r garrett turbo
custom downpipe and front exit exhaust
edelbrock intake manifold
rc 750 injectors
aem fuel regulator and fuel pressure regulator
hondata s300 with boost
wot you guys think?wot sort of power do you think this setup will achieve?
all comment welcome
cheers luke
Old Oct 31, 2007 | 11:34 AM
morgan@synapse motorsport's Avatar
Default Re: wot do you guys think?is this a good setup? (tics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tics &raquo;</TD></TR><TR><TD CLASS="quote">hi guys im from the u.k and i am currently in the middle of my boost build and just lookin for your opinions and help.wot do you think of this setup?
eagle rods
acl main bearings
cometic head gasket
standard head????
gt30r garrett turbo
rc 750 injectors
all comment welcome
cheers luke</TD></TR></TABLE>
id stick with a GE overbored oem head gasket weve used them without a single failure. and who is doing the sleeving?
how much power are you trying to make on this setup?
Old Oct 31, 2007 | 12:11 PM
tics's Avatar
the sleeving is goin to be done by a guy here in the u.k.he garuntees that they wont sink or fail.im looking for between 400-500hp and it will only be used at the weekend
Old Oct 31, 2007 | 12:18 PM
Default Re: (tics)
you are going to want larger injectors for 500whp, and i would put aftermarket springs/retainers in the car as well, we use supertechs.
in the words of Tommy Boy-
"i can take a crap in a box and mark it garanteed, really i got time..."
does he garantee the money to pull the motor out fix the problem and put it back in? i would hate to see you have an issue with the sleeving. i hope he has done a lot of honda blocks successfully.
Old Oct 31, 2007 | 12:27 PM
tics's Avatar
yeah i looked at supertech springs and retainers.so wot cams would i use?and would i have to get 1000cc injectors then?is the gt30r good enuff for 500whp?
yeah the guy said that if for some reason they fail or sink he would put the problem right and he has done a good amount of hond block so i think it will turn out alrite fingers crossed.
cheers luke
Old Oct 31, 2007 | 12:32 PM
Default Re: (tics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tics &raquo;</TD></TR><TR><TD CLASS="quote">yeah i looked at supertech springs and retainers.so wot cams would i use?and would i have to get 1000cc injectors then?is the gt30r good enuff for 500whp?
880cc injectors should work fine. stock cams as well.
Old Oct 31, 2007 | 12:37 PM
tics's Avatar
thanks for all the input buddy been a great help
Old Nov 2, 2007 | 07:48 AM
EM1 civic99's Avatar
Just wondering where you got your sleeves installed as i cant seem to find anyone in the UK to do it?
Dsalmeron
Mar 19, 2011 08:25 AM
94c1v1cex
Mar 10, 2008 10:07 AM
gsrturbo01
Dec 7, 2007 06:37 AM
Drkaccrd
Nov 21, 2006 06:47 AM
99black_em1
17
Aug 31, 2006 03:19 PM
