AEM map sensor problem?
Old Sep 27, 2011 | 11:04 AM
My_EFsedan's Avatar
Default AEM map sensor problem?
my friend has an s2k thats boosted. give or take ~300. everything is being upgraded from manifold to turbo to injectors etc.
1st thing he did is install his AEM 3.5bar map sensor and the car starts but doesnt stay on?? could the map sensor cause this problem?
car was running fine before that install.
Old Oct 17, 2011 | 08:42 PM
My_EFsedan's Avatar
Default Re: AEM map sensor problem?
noone really?
Old Oct 17, 2011 | 08:52 PM
90sedan's Avatar
Does it still have the stock ecu in it? If so, then that's probably the issue.
It's not like it takes long to swap map sensors, but the stock one back in and see if the car runs and then wait till the car is tuned to install the aem map sensor.
Old Oct 17, 2011 | 09:39 PM
My_EFsedan's Avatar
car is boosted with the greddy carb kit on emanage. stock map is back on. but its something to look into fixing when the new stuff is ready to go on. (drives fine now) then aem ems.
Old Oct 18, 2011 | 08:19 PM
90sedan's Avatar
When swapping to a higher reading map sensor, the settings in the ecu for the map sensor need to be calibrated or adjusted in order for the ecu to read the map sensor properly.
In short, there isn't a problem. Install the new map sensor with the aem ems and your tuner will take care of the rest.
Old Oct 18, 2011 | 09:50 PM
My_EFsedan's Avatar
alright, sounds good. ill let him know that. thanks!
JayDMJ
Engine Management and Tuning
Sep 9, 2017 12:24 PM
JTCdudeman
Nov 14, 2005 11:38 AM
ORcivicsi
Jul 12, 2005 01:48 PM
hovic
Sep 28, 2004 01:25 PM
burbel
May 6, 2004 01:22 PM
