My b18c5 Build
Hey guys finally finalized my build and im sticking to it. going for around 450-500whp/ useing a GT3582r. Going to tune on E85/Q16. around 25-30lbs of boost. let me know what you guys think!
and for driving on streets 91 on low boost
B18C5:
Darton sleeves
Arias 8.5C/R 84mm pistons
Manly Turbo Tuff I-Beams
ACL bearings
Stock GSR Crank
ARP Head studs
Head is a B16A
FULL supertech valvetrain with 1mm Oversized valves w/ Black nitride valves
head is beings decked
ITR Cams
MSD Ignition system
Victor X Intake mani
BDL 70mm Throttle body
Cometic Head gasket
750cc injectors
Golden eagle fuel rail
Adjustable fuel pressure regulator
AEM adjustable cam gears
Trans
Wavetrac LSD.
Spec stg 5 clutch
B18C5:
Darton sleeves
ACL bearings
Stock GSR Crank
ARP Head studs
Head is a B16A
ITR Cams
MSD Ignition system
Cometic Head gasket
750cc injectors
Trans
Wavetrac LSD.
Spec stg 5 clutch
Hey guys finally finalized my build and im sticking to it. going for around 450-500whp/ useing a GT3076r w/ P-Trim. Going to tune on E85/Q16. around 27-35lbs of boost. let me know what you guys think!
B18C5:
Darton sleeves
ACL bearings
Stock GSR Crank
ARP Head studs
Head is a B16A
ITR Cams
MSD Ignition system
Cometic Head gasket
750cc injectors
Trans
Wavetrac LSD.
Spec stg 5 clutch
B18C5:
Darton sleeves
ACL bearings
Stock GSR Crank
ARP Head studs
Head is a B16A
ITR Cams
MSD Ignition system
Cometic Head gasket
750cc injectors
Trans
Wavetrac LSD.
Spec stg 5 clutch
Bump the compression up to mid 9's, otherwise its a good build for the hp, sleeves werent needed for that power level but its added security, dont be concerned with boost pressure and just obtain your HP goal which is doable with a gt3076r, but like shodan said not available in ptrim wheel, gt is a gt wheel
BlangBlangTEG-93'
Mar 5, 2007 08:23 AM
ludesleep
May 30, 2003 02:54 AM
