Engine Troubles... :/
whats up HT
ok well here is my problem.. well i guess anybodies problem that has a swap.. So starting off i have 93 civic with a 95 b18b1 with a d series non v harness on it and a p75 obd1 ecu.. any way my problem is the car doesn't wanna start it will start when its completely cold but when it warms up a little bit that's the killer i put a brand new o2 sensor on brand new alt brand new dizzy. I also checked all of my grounds and everything also.. Has anybody on here had any problems with there B series swaps not starting? If so what was the fix?
If more info is needed let me know i just didn't want to write some long *** thread.
Old Fart
Re: Engine Troubles... :/
ECT sensor could be defective or ECU/ECM not reading it properly.
When trying to to start, [when warm] does it fire at all?
Try pulling a spark plug after trying to start, [when warm] and see if there is fuel on the plug and if you are getting spark. 94
On fire.. Idk what it can be but when the car sits over night it starts right up but the once it starts and gets hot no more..
Old Fart
Once it starts, will it keep running until you turn it off?
When trying to start, [when warm] will the engine fire at all, [sound like it may start?
If so, i would check the ECT sensor for proper operation, if it is not working it would indicate a cold engine, [even though it is warm] and air/fuel would be rich, [flooding] cylinders.
How is the gas mileage?
If your running rich your gas mileage would SUCK. 94
so i think i figured out what it was guys. the sensor that is on the side of the head is what is keeping my car from running when the car is hot i figured out when i unplug the harness from the sensor the car is running.. but now i got an idle problem.. the car is idling at like 2k soo its some bs.... i gotta fix the idle problem now.. any ideas??
was it the ECT sensor? theres only 2 sensors, 1 a single wire for gauge cluster, 2 a 2 wire ECT sensor for ecu. its either sensor or ecu
