Engine Troubles... :/
Old Aug 22, 2011 | 09:02 PM
Jay_Mills's Avatar
Icon6 Engine Troubles... :/
whats up HT
ok well here is my problem.. well i guess anybodies problem that has a swap.. So starting off i have 93 civic with a 95 b18b1 with a d series non v harness on it and a p75 obd1 ecu.. any way my problem is the car doesn't wanna start it will start when its completely cold but when it warms up a little bit that's the killer i put a brand new o2 sensor on brand new alt brand new dizzy. I also checked all of my grounds and everything also.. Has anybody on here had any problems with there B series swaps not starting? If so what was the fix?
If more info is needed let me know i just didn't want to write some long *** thread.
Old Aug 22, 2011 | 11:21 PM
civickiller's Avatar
Default Re: Engine Troubles... :/
any cel?
Old Aug 23, 2011 | 04:55 AM
Jay_Mills's Avatar
Originally Posted by civickiller
any cel?
i just had a code 10 thats it.. but i fixed that yesterday..
soo there isnt one anymore lol..
Old Aug 23, 2011 | 05:53 AM
fcm's Avatar
fcm
Old Fart
ECT sensor could be defective or ECU/ECM not reading it properly.
When trying to to start, [when warm] does it fire at all?
Try pulling a spark plug after trying to start, [when warm] and see if there is fuel on the plug and if you are getting spark. 94
Old Aug 23, 2011 | 04:58 PM
Jay_Mills's Avatar
Yea I did that yesterday te spark plug and the cylinder lit
On fire.. Idk what it can be but when the car sits over night it starts right up but the once it starts and gets hot no more..
Old Aug 23, 2011 | 05:20 PM
fcm's Avatar
fcm
Old Fart
Once it starts, will it keep running until you turn it off?
When trying to start, [when warm] will the engine fire at all, [sound like it may start?
If so, i would check the ECT sensor for proper operation, if it is not working it would indicate a cold engine, [even though it is warm] and air/fuel would be rich, [flooding] cylinders.
How is the gas mileage?
If your running rich your gas mileage would SUCK. 94
Old Aug 23, 2011 | 09:56 PM
Jay_Mills's Avatar
well the car isnt really driving i just finished the swap and i cnt really drive it becuase of this problem. and the engine doesnt fire at all (when hot) it just keeps turning and turning until you let go of the key. and my car isnt running to rich because when the car is actually on it has a nice little idle.. and yes it will stay on when i turn the key on it just wont come back on once i turn it off lol
Old Aug 25, 2011 | 09:46 PM
Jay_Mills's Avatar
so i think i figured out what it was guys. the sensor that is on the side of the head is what is keeping my car from running when the car is hot i figured out when i unplug the harness from the sensor the car is running.. but now i got an idle problem.. the car is idling at like 2k soo its some bs.... i gotta fix the idle problem now.. any ideas??
Old Aug 25, 2011 | 10:47 PM
apwhat's Avatar
start with the first problem, not the second problem which is a temp fix.. replace sensor, and check wirring
Old Aug 26, 2011 | 01:54 AM
was it the ECT sensor? theres only 2 sensors, 1 a single wire for gauge cluster, 2 a 2 wire ECT sensor for ecu. its either sensor or ecu
Old Aug 26, 2011 | 11:50 AM
fcm's Avatar
fcm
Old Fart
There is the ECT switch, it controls the rad fan, and the ECT senor it supplies ECU/ECM with engine temp. and the temp. gauge.94
aaronl29210
Sep 29, 2011 06:00 PM
onthagozc
32
Aug 24, 2009 07:54 PM
madball
12
Apr 2, 2007 05:10 PM
hmtcrxsir
Nov 30, 2006 01:35 AM
FOrSfEd
Jul 18, 2005 09:41 AM
