Del sol build
Ctr high compression pistons (11.5:1), p30 rods, acl rod bearings, apr bolts, stock Ls vtec head, td-44u distributor, skunk2 intake manifold, AEM fuel rail, 310cc fuel injectors, 68mm omni throttle body, 8.5mm spark wires, ngk one degree colder spark plugs, rmf header, Aem short air ram, 9.5lbs flywheel, stage 1 clutch kit, LSD transmission, hi-flow magnaflow cat, magnaflow muffler, 1.1L aluminum radiator. I'm deleting my a/c system and compressor. My ecu will have USB port for tuning hondata s300.
These are on my facebook. sorry.
-Entire motor/drivetrain build
http://www.facebook.com/media/set/?s...5255.554037413
-Swap in progress
http://www.facebook.com/media/set/?s...1309.554037413
-Swap in progress
TheProffessa
24
Nov 17, 2011 01:11 PM
markspan6243
63
Jan 14, 2009 07:44 PM
del slw
Dec 15, 2005 09:05 AM
