2000 civic overheating
Old Jun 8, 2011 | 07:11 AM
bdws6's Avatar
Default 2000 civic overheating
hi. i have a 2000 civic that overheats at high speeds around 60mph. and it will cool down fast when i turn on the heat. but who wants to drive on interstate with the heat on. it will also cool down when i slow down to around 35 to 40 mph. also i forgot it only overheats when the temp outside is 90 or higher. ps i changed the thermastste already. pleas help
Old Jun 8, 2011 | 07:54 AM
madjap's Avatar
Default Re: 2000 civic overheating
Need more info to be certain, but it sounds like you have a bad radiator.
Old Jun 8, 2011 | 08:17 AM
redm3turbo's Avatar
when you changed the thermo did you bleed the system?
check the rad for clogs/ proper function.......
Theres a thread on here that deal with this exact same issue....overheating system..
check it out
Old Jun 8, 2011 | 08:31 AM
bdws6's Avatar
how do you bleed the rad system
Old Jun 8, 2011 | 08:52 AM
that_boy_sammy's Avatar
Water pump maybe?
Old Jun 8, 2011 | 09:02 AM
Former User's Avatar
I'm thinking the same thing.
Bleeding the cooling system may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat. Fan need not be on.
3) Follow the directions in the diagram below
Old Jun 8, 2011 | 09:24 AM
madjap's Avatar
Originally Posted by that_boy_sammy
Water pump maybe?
Water pumps are rarely ever the problem on Honda engines, and this is why:
As long as the timing belt drives the impeller, the water is moving. Water pump generally fails when the seal goes bad on the impeller shaft, and the pump starts leaking coolant through the "weep hole".
I have seen an extreme case where the impeller was rusted away and it did not move any water...but that's one water pump in probably 5000 that I have seen. (I worked ten years as a parts guy at Napa, AZ and a local shop while in school)
Of course, since the coolant was just rusty water, it was weeping out of the hole.
Old Jun 8, 2011 | 09:29 AM
hiramclarketx08's Avatar
ITS YOUR RADIATOR U CAN GET ONE CHEAP BRAND NEW TOO
Old Jun 8, 2011 | 07:00 PM
bdws6's Avatar
will i tryed bleeding it. and it still overheats. but i looked at my radiator while i was down there and it was full of bugs and hloes i tryed hoesing out the bugs but i was putting more holes in the radiator. so ill get a new one this weakend and see what happens. thanks
Old Jun 9, 2011 | 11:13 AM
sounds good let us know wat happens n dat should be your problem. when too much debris gets stuck on your radiator it blocks air.
Old Jun 9, 2011 | 12:25 PM
StreetsideStig's Avatar
Yeah, radiators aren't too hard. Keep us updated!
Old Jun 17, 2011 | 06:43 AM
bdws6's Avatar
replaced the rad and been driving it around for a week now and no more overheating. the old rad looked really bad. thanks ereryone
Old Jun 20, 2011 | 05:17 AM
Awesome! Good fix, man.
TheGorneLord
Honda CR-V & Element
Apr 5, 2018 02:35 PM
Manifest113
Jul 30, 2014 06:09 PM
Neo218
18
Mar 6, 2010 08:16 PM
mrfootball420
18
Sep 29, 2009 09:40 PM
ericschimmel
May 31, 2008 06:36 AM
