2000 Civic overheating, backfiring and studdering... possibilities?
Old May 28, 2008 | 04:05 PM
ericschimmel's Avatar
Default 2000 Civic overheating, backfiring and studdering... possibilities?
Ok, so it all started about a week ago. Car was overheating pretty bad but it would eventually cool down. So, I changed the thermostat since its the cheapest thing on the list. Worked a little, but it still overheats after a about 15 minutes of driving. Then today when I was taking off from a stop light, the car started studdering and backfiring after about 3k rpm from second gear up. Any ideas what the problem could be? I was thinking headlift, but I have ARP's so I don't know. Any help would be greatly appreciated!
Modified by ericschimmel at 5:10 PM 5/28/2008
Old May 28, 2008 | 07:16 PM
inspyral's Avatar
Have you verified all the usual cooling system components? Is the fan coming on? Is there any air in the cooling system? Are you mixing any oil/coolant? Are you only overheating after boosting?
Old May 29, 2008 | 02:30 AM
Fan IS coming on. I just rewired it to a switch so i can control it. purged the system 3 times now. I'm not mixing oil and coolant and i just replaced the head gasket about 500 miles ago. And yeah, it seems like it overheats after boosting.
Old May 29, 2008 | 08:48 AM
UPDATE
Car didn't studder this morning and has been running fine except for the overheating problem. Anyone have any ideas?
Old May 29, 2008 | 10:45 AM
1fastlude1's Avatar
Default Re: (ericschimmel)
check ur ground wires with it backfiring and misfiring thats what it sound like
Old May 29, 2008 | 11:30 AM
inspyral's Avatar
Does your coolant reservoir fill up after boosting?
Old May 31, 2008 | 05:46 AM
Default Re: (inspyral)
yeah, it overflows pretty bad
Old May 31, 2008 | 06:02 AM
gettin it's Avatar
Sounds like a headgasket bro. How tight did you tighten the headstuds? And what headgasket did you use. Any lube on the bolts and nuts? Did you go back and re-tq the studs?
Old May 31, 2008 | 06:11 AM
ARP head bolts, OEM gasket, 60 ft. lbs is what i was told. and yes, i went back and retourqed after a week and they were still tight.
Old May 31, 2008 | 06:36 AM
HamiltonRex's Avatar
do a compression and leakdown test, and pressure test the cooling system.
skyliner34life
Dec 23, 2014 10:33 AM
Manifest113
Jul 30, 2014 06:09 PM
96_RHD_EK
21
May 1, 2008 08:11 AM
PureEF8
Jan 20, 2006 06:28 PM
aflacsonke
Sep 20, 2002 11:36 AM
