ECU self-diagnostic
Old Sep 28, 2002 | 03:05 PM
Cynical 1's Avatar
Default ECU self-diagnostic
Ok. I've searched every forum and found nothing...
Is there a way that I can make the ECU do a diagnostic check myself? My CEL light is on, and I need to see what code it is, but my Chilton service manual doesn't tell me how to do a diagnostic check, it just lists the codes.
I have a 93 Civic CX with 95 B18C1 and P72 ECU.
Old Sep 28, 2002 | 03:28 PM
forthgeneration's Avatar
Default Re: ECU self-diagnostic (Revolveu2)
well for my lude, if you look behind and under the radio there are two different open harnesses. one is blue and one is grey. Take a paper clip and bend it into a "U" and stick it into the blue one and turn on the car (but don't start it). the cel light should blink a certain number of combinations.
short blink= 1
long blink= 10
e.g.: Long blink, long blink, short blink, short blink would equal 22. you might get a number of different codes also.
alan
Old Sep 28, 2002 | 03:34 PM
miahmouse's Avatar
I think for your car the plug that you need to jump is in the passengers kick panel. The plug should be a two wire blue or green plug (I'm colorblind, can't tell which). Sometimes it's stuck in a little rubber holder thing. Then just go with what the other guy said (paperclip, cel blinks codes)
Old Sep 28, 2002 | 07:07 PM
tSuperbike69's Avatar
Default Re: ECU self-diagnostic (miahmouse)
Your car has a jumper harness in the pass. side kickpanel like said before. There will be a 2 plug connector with a rubber green plug around it. Remaove that and jump the wires together. Watch the cel light and count the codes. short=1 long=10
Old Sep 28, 2002 | 07:23 PM
salbaje's Avatar
here you go
http://www.c-speedracing.com/faq/06.html
Old Sep 29, 2002 | 04:24 PM
Cynical 1's Avatar
Default Re: ECU self-diagnostic (tSuperbike69)
Cool. Thanks a lot guys!
92DAB16A
Sep 14, 2012 07:14 PM
rhoades
10
Dec 28, 2009 12:42 AM
righteyeblind
Jun 30, 2008 01:50 PM
b16ahybrid
Feb 28, 2006 04:10 PM
93EH6
Jan 30, 2003 09:11 PM
