water/meth
Old Apr 7, 2011 | 01:35 PM
93lsv_turbo's Avatar
Default water/meth
im from a hot/humid area (fl to be exact) this summer i'm planning on upping the boost on my car. i was wondering at what point (whp/heat) would it be a good idea to install a water/meth kit. this is going in a stock ls/vtec with a t3/t04e 57 trim .53 ar. my hp goal is 375 400. e85 is not an option and a typical fl day in the summer is 90deg 90% humidity and the nights are really not any better
Old Apr 7, 2011 | 03:03 PM
TheShodan's Avatar
Moderator
Default Re: water/meth
Here..
http://www.ehow.com/how-does_5019536...tion-work.html.
It is dependant upon exactly WHERE you start to get detonation based upon the fuel used. Whether its 90 degree day with lots of humidity or not, the engine itself will see more internal combusted radiant heat
Old Apr 7, 2011 | 03:22 PM
LightningTeg's Avatar
Community Builder
You should be able to hit those numbers on a good setup on straight 93
Old Apr 7, 2011 | 03:51 PM
wantboost's Avatar
Who is Mr Robot?
Not stock bottom end he wont
Old Apr 7, 2011 | 05:37 PM
Community Builder
Sure he can lol. Reliability isnt going to change by adding meth in the case you are referring to.
Old Apr 7, 2011 | 05:50 PM
Originally Posted by TheShodan
Here..
i've actually read this exact article lol. i understand that the engine itself will be the main cause of my heat problem but if the ambient temp is 110deg then thats as low as i can get my charge/intercooler temp regardless of the size of the intercooler. so i was looking for kinda a cheat to bring my temp/knock down
i know that i dont have the most ideal setup but im in the army and if the block last a year... well i'll gone for a year
Old Apr 7, 2011 | 05:56 PM
JoHnnY LonGHoRn's Avatar
u dont need methonal ..... point blank..... on a good tune and s300 u can regulate your IAT ur not in the hp range to even think about meth..... im from ny and i run turbo all summer long my IAT never goes above 130 even in 100% humidity ........ i suggest fan control and type 2 antifreeze from the dealer
Old Apr 7, 2011 | 05:58 PM
[QUOTE=LightningTeg;45031059]Sure he can lol. Reliability isnt going to change by adding meth in the case you are referring to.[/
ur right it wont hurt but spend the $$$ on summin else
Old Apr 7, 2011 | 06:12 PM
thanks for all the help i think im gona stay around the 350 375 area and be happy for a year. lol sometimes i should just be happy with what i have. i mean that should be alots of fun on the street
Old Apr 7, 2011 | 06:16 PM
im makin the same power lots of fun for the street bump for boost N/a is narcotics anonymous!!!!!!!!!!!!!!!!!!!
Old Apr 7, 2011 | 06:17 PM
how does it run in the summer
Old Apr 7, 2011 | 06:24 PM
fine i actually take out my therm set my fan to 160 ...... i have a jdm teggy so the dual core , even the single core doesnt fit right...... so i used a blackworks slim fan and a 2000 si rad cuz there thicker for a/c and shes good..... it heats up when i beat on it but it does that in the winter ,,,,, but i mean beatin it
Old Apr 7, 2011 | 06:39 PM
yeah but damn i mean everything under my hood is CRAZY hot. take it i have a stock civic rad and fan.
Old Apr 7, 2011 | 06:46 PM
wedge the hood instead of gettin a meth kit buy some nrg hood dampers and shims wedge the hood natural cowl will help keep the engine compartment cooler and u can also get a turbo blanket
joppe
Oct 14, 2009 11:55 AM
Rigginit
Dec 21, 2006 09:58 PM
TegRaceR98
Jan 12, 2005 09:30 PM
blufke
Nov 19, 2002 07:32 PM
