Need help with struts. Pics
Old Mar 30, 2011 | 08:11 AM
hyperblu's Avatar
Default Need help with struts. Pics
I have a 99 em1 and ordered some used struts and springs off another 99 hx i believe. Anyway, my fork will not slide on because the bottom is a different shape and has a stopper. Advice?
Old Mar 30, 2011 | 08:14 AM
05foresterxt's Avatar
Default Re: Need help with struts. Pics
I think u answered your own question.
Old Mar 30, 2011 | 08:15 AM
hyperblu's Avatar
Thought I could use any 96-00 parts?
Old Mar 30, 2011 | 08:38 AM
I'm not sure, but if they are different, then they won't fit.
Old Mar 30, 2011 | 08:45 AM
hyperblu's Avatar
I can get the fork on it, and almost get the pin in the fork on, but i need about 1/2" clearance... Guess ill need a spring compressor...
Old Mar 30, 2011 | 08:50 AM
IhateworkingoncaRs's Avatar
The spring compressor will only help get the spring on the strut, it won't do anything else.
Old Mar 30, 2011 | 08:51 AM
grumblemarc's Avatar
The Grumpiest
What do you need a spring compressor for? The springs a re already on the strut.
Old Mar 30, 2011 | 08:56 AM
hyperblu's Avatar
With the fork on, I can't quite slide the bolt through the lower control arm...
Old Mar 30, 2011 | 08:58 AM
The Grumpiest
Well the spring compressor isn't going to help that.
Old Mar 30, 2011 | 09:00 AM
hyperblu's Avatar
Then how do i compress the strut another half inch to get the bolt through?
Old Mar 30, 2011 | 09:03 AM
Make sure your spring is tighten all the way down and the fork is all the way up. Next, you'll have to pry down your LCA. If it's not the proper fit, your civic is going to look like it has a lift kit in it LOL. sorry.
streetglowjoe's Avatar
push down or up on the lca to make it line up
Old Mar 30, 2011 | 09:15 AM
hyperblu's Avatar
I do need a spring compressor. If I compress the springs, I can adjust the top hat with the allen wrench and bring the strut up... know what i mean jelly beans?
The Grumpiest
You need to get creative. I used a scissor jack on the bottom part of the fork to push it up while the pushing down on the LCA.
Old Mar 30, 2011 | 09:16 AM
hyperblu's Avatar
the lca's are all the way down... the thread at the top of the strut tower is less than my old ones, meaning I have to tighten the top of my tophats to bring the strut up..
Old Mar 30, 2011 | 12:15 PM
hyperblu's Avatar
Got it figured out. the previous owner hammered off the stoppers, which I guess is a ghetto way of lowering the front end... got it all buttoned up now... Drives like a dream compared to the old ones...
Toolman
Suspension & Brakes
May 2, 2005 06:30 AM
hondaracing1
11
Mar 24, 2005 06:24 PM
eclecticteg21
Nov 3, 2004 01:16 PM
ryaneg6
Nov 17, 2002 12:07 PM
Ignitecivic
Mar 17, 2002 04:37 PM
