Tach not working need help
Old Mar 14, 2011 | 03:25 PM
eljah0426's Avatar
Default Tach not working need help
Okay after extending the driver side harness and replacing the cabin harness my tch no longer works I installed it in a friends car so i know it works I also have no breaks in the blue tach signal wire I also replaced the icm in the distributor what could be the problem how can I narrow this down car is a 94 civic si with gsr swap thanks
Old Mar 14, 2011 | 03:27 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Tach not working need help
It's obviously a wiring issue. The tach worked prior to extending wires?
Old Mar 14, 2011 | 03:29 PM
tlarimer's Avatar
Sometimes the tach just goes bad, on my 92 EH3 I had to tap the cluster to get the tach to register, swapped out the cluster with a VTi and problem solved.
So if your sure the wire is good from the dizzy to the cluster plug, than that would be my guess.
Old Mar 14, 2011 | 03:42 PM
eljah0426's Avatar
I put the tach in a friends car yesterday and it worked fine and yes it work before the extending
Old Mar 14, 2011 | 03:45 PM
tlarimer's Avatar
Then I agree with grumblemarc, it's gotta be in the wiring. Did you test the tach signal wire? or just a visual inspection?
Old Mar 14, 2011 | 04:01 PM
eljah0426's Avatar
I tested it on a multimeter on vac 200 it read 6.5 I believe at idle and would go up when I reved it up
Old Mar 14, 2011 | 04:07 PM
tlarimer's Avatar
Is that at the signal wire pin on the cluster connector?
Old Mar 14, 2011 | 04:24 PM
eljah0426's Avatar
Ya the solid blue wire behind the cluster do u know where I can find a pin out for the driver side harness I can only seem to find the passenger side
Old Mar 14, 2011 | 05:03 PM
tlarimer's Avatar
Sorry, I do not.
Old Mar 14, 2011 | 05:59 PM
eljah0426's Avatar
Nevermind thx guys I got it I had the tach signal wire in the wrong place on the cluster
ramco
Mar 6, 2010 07:30 PM
Naudlee
19
Aug 20, 2006 08:20 AM
PINKS
May 11, 2006 05:36 PM
R6Boy69
Oct 24, 2003 09:05 AM
B19CivicHB
Oct 31, 2001 09:53 AM
