Tach doesn't work need help
my tach in my cluster doesn't work right now i think the problem is in the wiring. When I bought the car it was a wiring mess... Now i just need to know what wire in the harness is for the tach signal?
Re: Tach doesn't work need help (poison)
so is it still dark blue at the cluster? I know the problem has to be either at the cluster wiring or at the computer cause thats where the guy messed with it.
I guess I need to know where on the cluster plug is the tach signal wire.
Re: Tach doesn't work need help (crXBoy69)
Yes, it comes from the distributor and is wired directly to your gauge cluster.
I would grab a digital mutimeter and test for open circuit at the blue pin on the gauge cluster connector, then use the other terminal at the distributor.
do you know where the wire runs? does it run through the wiring harness on the drivers side or through the wiring harness to the computer?
Re: Tach doesn't work need help (RdCivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RdCivicSi »</TD></TR><TR><TD CLASS="quote">who needs a tach just listen to your car.</TD></TR></TABLE>
Its still a nice selling feature to sell a car with everything working.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crXBoy69 »</TD></TR><TR><TD CLASS="quote">do you know where the wire runs? does it run through the wiring harness on the drivers side or through the wiring harness to the computer?</TD></TR></TABLE>
It runs directly to your tach through the driver side shock tower harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
It runs directly to your tach through the driver side shock tower harness.</TD></TR></TABLE>
Thanks poison, you've been a great help
vtechjunkie
28
03-16-2010 11:14 AM
