DIY: 92-95 EH/EG/EJ Low fuel sender installation and wiring
Old Mar 7, 2011 | 02:07 PM
tlarimer's Avatar
Default DIY: 92-95 EH/EG/EJ Low fuel sender installation and wiring
Well this will be my first DIY, so bear with me...
This will guide you through installing a JDM/USDM low fuel sender into a USDM 92-95 EH2/3 Civic Hatchback, the installation should be the same for other bodies, but I don't know if the low fuel sender is the same P/N.
What you will need:
USDM low fuel sender P/N 37800-S04-305
1 pin from cluster connector
1 male/1 female pin from standard Honda connector
1 large female pin
RED/GRN stripe wire(parking brake wire from 92-95 civic)
JDM/EDM cluster with low fuel light or modify your USDM cluster
I'm not going to go into detail for removing cluster, back seats and replacing USDM fuel sender with low fuel sender, but they need to be removed and new low fuel sender need to be installed.
You are basically running one wire from Pin A7 at the cluster back to Pin 3 in the fuel sender connector. But I like to try and keep everything nice and clean, so I ran the wire through the blue connector at the top left of the fuse box for a cleaner install.
Well there you have it, if you did it correctly, then your low fuel light should work, if not check all your connections.
You can test the low fuel light by jumping Pin 1 and 3 on the fuel sender connector, turn the key on and low fuel light should come on.
Feedback welcome, but keep in mind this is my first DIY and I can adjust anything you feel lacking or needs more attention.
Special thanks need to go to Deschlong for his help and diagrams.
Thanks,
Tim
Old Mar 7, 2011 | 02:13 PM
votoms888's Avatar
Default Re: DIY: 92-95 EH/EG/EJ Low fuel sender installation and wiring
Nice. Thanks for the post. It'd be nice to know how low the fuel level is.
Old Mar 7, 2011 | 02:19 PM
Black Diamond's Avatar
Nice bro, looks like your pics are messed up though!
Old Mar 7, 2011 | 02:22 PM
tlarimer's Avatar
Fixed
Old Mar 9, 2011 | 02:03 PM
tlarimer's Avatar
Fixed all picture links and added information
Old Mar 9, 2011 | 03:56 PM
Former User's Avatar
Link added to FAQs sticky.
Old Mar 9, 2011 | 04:11 PM
Gunmetal_B20_Hatch's Avatar
coolsies... What clusters had this?
Old Mar 9, 2011 | 04:19 PM
tlarimer's Avatar
Most JDM and EDM clusters, but not all, be cautious. The one I installed is a EDM EG6 VTi cluster.
But you can also modify your USDM cluster, like in this thread:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bcivic-92-95%5D-usdm-fuel-temp-gauge-question-2862483/
Old Mar 26, 2011 | 10:31 PM
jmaze's Avatar
nice with pics!
Old Mar 27, 2011 | 12:03 AM
ElliotSiR's Avatar
Added to my IE favorites. I'll be doing this once I get an actual cluster rather than my garbage stock one with no tach.
Old Mar 27, 2011 | 01:17 AM
Need_jdm's Avatar
dope!!! ill do this later today
Old Apr 13, 2011 | 08:12 PM
jmaze's Avatar
I finally got around to wiring mine but used the up-shift arrow on my cluster since I have a vx. I jumped it so I know it works just waiting for the tank to get low.
Old Jul 10, 2011 | 02:24 PM
tlarimer's Avatar
Updated, added schematics and diagrams
Old Jul 10, 2011 | 05:53 PM
BryanM.'s Avatar
Resident Gearhead
Great write up and I want your gauge cluster.
Old Jul 10, 2011 | 06:07 PM
tlarimer's Avatar
Thank you, you can usually find them on UK ebay for $100-$125 shipped to the US
Old Jul 10, 2011 | 06:16 PM
BryanM.'s Avatar
Resident Gearhead
Thank you.
Old Aug 3, 2012 | 04:12 AM
Andres-David's Avatar
Wow! thanks for the info, I'm gonna do it in my civic !
Old Nov 25, 2013 | 07:56 PM
SozeHuck's Avatar
Thanks for the sender Part number!
Old Dec 26, 2013 | 11:48 AM
olfirehand's Avatar
Just bought a UKDM cluster for my CRX which has a low fuel light. Do you or anyone else happen to know if the sender you used (part number above) is usable on my car. I have a USDM 1988 CRX SI and I replaced my fuel level and fuel pump last year. Any help would be much appreciated.
Old Dec 26, 2013 | 12:05 PM
95Sedan's Avatar
you could do this with an LED placed somewhere else besides cluster right?
Old Feb 19, 2018 | 09:29 AM
Riptide101's Avatar
Any possibility of reuploading the photos?
Old Feb 21, 2018 | 10:35 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Photos work for me .... I expect you need the photobucket hotlink fix: (for chrome) https://chrome.google.com/webstore/d...er-info-dialog
LuckyStrike90
Apr 25, 2018 03:10 PM
deschlong
28
Jun 29, 2017 11:24 AM
fungus mungus
93
Dec 9, 2011 07:35 AM
jmaze
Oct 24, 2007 07:31 PM
hatchii
Nov 4, 2002 02:43 PM
