96 ITR swap in a EG
im helping a buddy put a 96 integra type r swap into his 93 civic Si. its coming with the harness and ecu. i know it theres a obd1 to obd2a ecu jumper but will the engine harness be a plug and plug to the obd1 harness plug for the engine harness? not too familiar with obd2 conversion but since the swap is coming with the ecu we want to keep it obd2 .
a 96 is obd2 92-95 are obd1
First off, you would need to extend some wires since you're using a RHD harness. Second, it will plug into the strut tower harness. Third, you will need a chipped OBD1 P28/P30/P72/P06 etc.
Yes, the OBD2 ITR Engine harness is a 2-piece design that is 100% plug-and-play with the EG chassis. You'll need a jumper harness to plug the ECU in. Easiest swap in the Honda world.
You'll also want to get an OBD1 alternator and injectors, or cut and splice the plugs from the RHD harness, you could use a chipped and tuned P28 in either case.
Sinner
Jan 4, 2006 05:28 PM
3.point.2
Jul 8, 2004 06:06 PM
JDcompman
Apr 14, 2004 09:33 PM
