IDLE problem with 1996 civic
Old Mar 1, 2011 | 07:16 PM
2000em1boycivic's Avatar
Default IDLE problem with 1996 civic
fa
Old Mar 1, 2011 | 08:01 PM
Choppin's Avatar
Default Re: problem with 1996 civic
check for a vacuum leak or if not its your IACV (Idle Air Control Valve) its behind the throttle body...i have a 97 hx with the same motor nd had the same problem
Old Mar 1, 2011 | 10:48 PM
tklee's Avatar
GLW Fixing...
Old Mar 1, 2011 | 10:54 PM
apexi_rsx's Avatar
you have to have a vacuum leak to have your idle that high and surging. spray carb cleaner around the intake manifold and see it the car revs up more or chokes up. then check the spot for a leak.
Old Mar 2, 2011 | 07:02 AM
it only does it in 2-3k then when is get to 4k its all good then when its idling it just revs to 1.5 and back down to 1k
Old Mar 2, 2011 | 07:04 AM
grumblemarc's Avatar
The Grumpiest
Did you check this?
Old Mar 2, 2011 | 08:25 AM
im going to check that today
Old Mar 2, 2011 | 09:32 AM
Former User's Avatar
Default Re: IDLE problem with 1996 civic
Please create descriptive, topic specific thread titles -- edited.
Old Mar 2, 2011 | 03:29 PM
ok i put the car on the computer and this it what it showed
manifold absolute pressure or barometric pressure circuit high input p0108
throttle/pedal position senor a circuit low input p0122
intake air temperature sensor circuit high input p0113
evaporative emission system pressure sensor / switch p0450
Old Mar 2, 2011 | 05:21 PM
bump
Old Mar 2, 2011 | 05:33 PM
Do all of these codes return after resetting the ECU?
Old Mar 2, 2011 | 05:40 PM
there was a leak by the manifold but i fixed it but it does the same thing but my car never dies it just does that throught 2-3k rpm and everything is good when it passes 3k or if i shift it at 2k and after i rest the computer the codes just come back agian
Old Mar 2, 2011 | 05:47 PM
P0113 - Is the IAT sensor plugged in?
P0450 - Is the gas cap missing or is the cap seal broken? This can also be caused by a vacuum leak.
P0108 & P0122 - Are the MAP sensor and TPS connectors swapped?
PTVDesign
Dec 27, 2009 04:50 PM
civc_tt
Jul 30, 2006 11:00 AM
h22831
Jul 18, 2005 06:36 PM
STUCKED
Mar 1, 2005 12:52 PM
4gen
Jan 11, 2004 05:28 PM
