Exhaust
I was told by the person I bought my car from that my car was tuned with a 5 ft long down pipe and that is it. I extended the pipe to the back of the car (3 inch). I want to put a muffler on it now. It is going to change the tuning of the car if I put a strait-through muffler on the end? It is set up for 25 psi.
It is a 95 Civic with a 1.6 vtec sohc.
It has Wiseco pistons, Eagle rods, Acl bearings, Supertech block guard, Arp rod bolts and head studs, full machine work from P&R in Pittsburgh, 255 Walboro fuel pump, Presicion 880cc injectors with resitor box, ported and polished head, Omni 4bar map sensor, 3 inch intercooler piping with a 32x12x4 intercooler, 50 trim turbo pushing 25 pounds.
It was dyno tuned by Pittsburgh Performace for around 360 hp and 312 tq and it has a Hondata s300 computer in it. The whole engine has a total of 3000 miles on it now.
Slap a muffler on it. If there is a big change in performance then you'll have it get it re-tuned. No way around it. No one can tell you what will happen for certain. I can guess that the change will be negligible.
Do you have a wideband?
It's going to change the air flow, so yes it's going to throw the tune off. A/F readings will be different.. and that could be leaner or richer.. IE: Can be dangerous
If it was mine, I would retune.. period.
If he's got a wideband, i'm sure it will be fine... waiting for that answer
No I don't have wide band. I just have 3 inch pipe running to the back of the car right now. I just had that done... I was getting carbon monoxide in the car (about 150 pom). Do you think just adding a peice of 8 ft pipe could change the tune by too much? I'm not wot all the time, I get on it probably 2-3 times a day for about 10 seconds at a time.
I would use a 3" catback so you dont have a restrictive flow. use and straight thru muffler (vibrant sleeper, magnaflow) and maybe even an inline resonator and yu wont have any issues.
Heres 3" kits on the cheap:
http://www.vrsexhaust.com/TUBING_KIT.../honda_tk.html
So your saying.. Downpipe off turbo -> To 5 foot of exhaust and that's it?
