What happens when you use a cheap compression tester....
Old Dec 30, 2010 | 01:33 PM
BearsEK-KMSU's Avatar
Default What happens when you use a cheap compression tester....
A friend of mine recently compression tested his GSR. He compression tested it, removed the guage from the hose which is a quick disconnect. He didn't know that the ***** that lock the quick disconnect fell down into the spark plug well, then he proceeded to unscrew the hose that threads into the spark plug hole and the ***** then made it into the cylinder. He found out real quickly that something was wrong.
No more Harbor Freight tester for Him.... HAVE A HAPPY NEW YEAR!
Old Dec 30, 2010 | 01:37 PM
sanjiyan69's Avatar
Default Re: What happens when you use a cheap compression tester....
OUCH.
Old Dec 30, 2010 | 02:22 PM
jdmcivic2fast's Avatar
ball bearing chambers
Old Dec 30, 2010 | 02:30 PM
94eg!'s Avatar
#1 Super Guy
Loved
Uh.....you can buff that out...
Old Dec 30, 2010 | 02:49 PM
xSteve_Ox's Avatar
holy **** that's crazy
Old Dec 30, 2010 | 03:04 PM
turbociv910's Avatar
mine fell apart luckly it didnt fall into the chamber,,, ouch.
Old Dec 30, 2010 | 03:25 PM
94eg!'s Avatar
#1 Super Guy
Loved
Makes me glad my cheapo Harbor Freight tester doesn't have a quick disconnect. Of course I still don't trust it's accuracy. Also the bleed valve is now leaking when I use it. I need to invest in a good one some time. Any suggestions for something inexpensive yet dependable?
Old Dec 30, 2010 | 03:29 PM
cannan's Avatar
It will be fine. Just put some tussin on it
Old Dec 30, 2010 | 04:10 PM
enemy no1's Avatar
just a few little dings no big deal, just put the head back on and run it like that! lol
Old Dec 30, 2010 | 11:44 PM
FlewByU352's Avatar
Just fill in the holes with weld and grind it down then have the head shaved. Might work?
Old Dec 31, 2010 | 04:46 AM
95skunkedgsr's Avatar
looks like it did a number on one of the valve seats
Old Dec 31, 2010 | 05:15 AM
Furyof4's Avatar
My $60 Craftsman tester works great and came with a lot of adapters to fit just about any engine. Also came with an adapter to pressurize the cylinders which comes in handy for swapping valve springs.
Old Mar 8, 2013 | 08:03 PM
raverx3m's Avatar
damn. sorry to bump i ve been using harbor freight tester as well lol
dimpled surface better aerodaynamics i guess.
good to know
Old Mar 8, 2013 | 10:07 PM
kingofbattle909's Avatar
still good though! that'll buff right out!
Old Mar 10, 2013 | 03:34 PM
JeffBro's Avatar
too bad it nailed the edge of the valve seat. Hes gonna have to take it to cylinder head shop to fix that valve seat
Old Mar 10, 2013 | 03:57 PM
Macho85's Avatar
Dammmm that sucks
Old Mar 12, 2013 | 05:22 PM
1998GsRIntegra's Avatar
Looks exactly like one of my previous engines after a screw from a skunk2 throttle body butterfly went through the engine.
B_Swapped93
May 21, 2013 06:54 PM
gjbraun
Jun 18, 2012 10:57 AM
NegativeXero
11
Aug 18, 2006 06:52 PM
iHOPEyouCHOKE
Apr 21, 2006 06:40 AM
scartail
Aug 17, 2005 06:26 PM
