What happens when you use a cheap compression tester....
A friend of mine recently compression tested his GSR. He compression tested it, removed the guage from the hose which is a quick disconnect. He didn't know that the ***** that lock the quick disconnect fell down into the spark plug well, then he proceeded to unscrew the hose that threads into the spark plug hole and the ***** then made it into the cylinder. He found out real quickly that something was wrong.
No more Harbor Freight tester for Him.... HAVE A HAPPY NEW YEAR!
#1 Super Guy
Re: What happens when you use a cheap compression tester....
Makes me glad my cheapo Harbor Freight tester doesn't have a quick disconnect. Of course I still don't trust it's accuracy. Also the bleed valve is now leaking when I use it. I need to invest in a good one some time. Any suggestions for something inexpensive yet dependable?
too bad it nailed the edge of the valve seat. Hes gonna have to take it to cylinder head shop to fix that valve seat
Looks exactly like one of my previous engines after a screw from a skunk2 throttle body butterfly went through the engine.
B_Swapped93
05-21-2013 06:54 PM
gjbraun
06-18-2012 10:57 AM
NegativeXero
11
08-18-2006 06:52 PM
