changing internal wastegate on 14b turbo
Old Nov 18, 2010 | 01:59 PM
aznboi_106's Avatar
Default changing internal wastegate on 14b turbo
so i have a 14b turbo and it is set as 9psi...i want to lower it to 5 or 7psi...it is a internal wastegate.. will an ebay internal wastegate that is for 7 psi work? is there any other way i can lower it?
thanks in advance
Old Nov 18, 2010 | 06:23 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: changing internal wastegate on 14b turbo
i doubt you'll be able to get that low with an internal w.g. unless you wanna port it out and buy a new flapper for it. why not just run it at 9lbs?
Old Nov 19, 2010 | 12:48 AM
aznboi_106's Avatar
i have stock internals....and i dont want it to blow on the dyno....but yes to block guard or no?
Old Nov 19, 2010 | 01:41 AM
Loved
Community Favorite
I had a turbo d16z6 on 14.7lbs for over a year and it never blew. just tell the tuner to tune it safely and you should be fine. as for the block guard, no you'll just make things worse. Iv seen it happen before.
Old Nov 19, 2010 | 01:57 AM
aznboi_106's Avatar
oh ok and u have stock internals right? alright....thanks...uh would a thicker head gasket help?
Old Nov 19, 2010 | 04:39 AM
Loved
Community Favorite
ya stock internals and stock headgasket will be fine. just make sure you have a walbro fuel pump and at least some 345cc injectors or bigger and that your tuner knows how to tune and it should be good.
Old Nov 19, 2010 | 05:37 AM
wmac's Avatar
seriously??
to adjust the intrenal waste gate:
Loosen the nut and take the rod off of the flapper.
To lower the boost, turn the rod and make it longer.
To raise the boost, turn the rod and make it shorter.
Then re-attach it to the flapper
Old Nov 19, 2010 | 08:22 PM
aznboi_106's Avatar
Originally Posted by wmac
seriously??
oh ok...i have to remove the internal wastegate off?.....
aznboi_106's Avatar
im using a cometic headgasket with 0.051"
Old Nov 19, 2010 | 08:23 PM
aznboi_106's Avatar
seriously??
is there a diy with pix?
Old Nov 20, 2010 | 05:43 PM
wmac's Avatar
really, its not that hard
a healthy d-series motor can take anything a 14b can dish out.
an un-healthy one shouldn't be 'boosted'.
however, if you want to adjust the amount of 'boost' it puts out, here is the procedure:
this is on my 15g, similar but NOT identical.
loosen locknut(green arrow)
remove cotter pin (red arrow) carfully, you want to be able to put it back on
slip endlink (blue arrow) off wg arm (purple arrow).
turn endlink one way will make it longer, the other way shorter.
once you have the desired length, slip endlink back on the wg arm and put back the cotter pin.
tighten the lock nut.
xfletcherxx
Jun 15, 2006 06:22 PM
abmerop18
Jan 27, 2005 08:05 AM
civic2nr9177
Apr 11, 2004 06:25 PM
SEVENSIX
Sep 9, 2003 01:06 PM
