TPS and Hondata S300...
Old Oct 15, 2010 | 10:46 AM
minilogoguy18's Avatar
Default TPS and Hondata S300...
I was told that I could get the readout of the TPS sensor via laptop connected to the S300 but I couldn't see this anywhere only throttle %. Asking cause I just want to make sure the sensor is set right and getting back there with multimeter probes is kinda a PITA. Thanks for any advice.
Old Oct 15, 2010 | 11:33 AM
A Blue Lude's Avatar
Default Re: TPS and Hondata S300...
S300 is just mapping the voltage to a %. It should be using the standard values, although you can probably change them.
Old Oct 16, 2010 | 08:57 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Throttle percentage should mimic TPS values. With KOEO WOT should be around 80-90% and closed your percentage should read around 0-4% The values vary between makes. If the voltage is incorrect you will notice drive ability problems. But you can make a correlation between the two values.
Old Oct 17, 2010 | 07:51 AM
Thanks, thought it would show me the same readout I would get with a multimeter like 0.5v at idle and 4.5v at WOT. It was actually spot on reading 0% at idle, I just wanted to rule this out as the slight hesitation I seem to be getting at like 2-5% throttle while cold but when warm it isn't there. Could be from the Euro R mani and lack of FITV even though the basemap from phearable runs the car great otherwise.
I actually set the TPS just by hitting the throttle and turning it until I got the best response, easier than people think without a multimeter.
Old Dec 26, 2018 | 12:25 PM
R1z1nginfern0's Avatar
Did you ever find out what the issue was? I actually am running the same setup on a used car I just purchased and I am having the same exact issue. I recalibrated with the s300s throttle interpolation readjustment because it was reading I think like 1% closed and 92% wide open and it slightly got better but it is still present. I know this is a dead thread but I would really appreciate any feedback. Thank you.
krc91987
May 26, 2014 11:05 AM
milanoteggy
Jul 13, 2012 10:10 PM
Steeve_Civic
Jan 6, 2012 12:51 PM
jake1191
Engine Management and Tuning
Jul 18, 2011 06:42 AM
92WhiteEG
Feb 10, 2005 11:15 AM
