Old Mar 31, 2015, 04:37 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Overview
Print Wikipost
Just bought a 98 civic HX...How maximize MPG?
Old Sep 5, 2010 | 07:00 PM
Turbotype's Avatar
Default Just bought a 98 civic HX...How maximize MPG?
and I have some questions about it....First off, it's the D16y5, which is the econ vtec motor...I'm looking for ideas on what I can do to maximize my MPG...I already plan on changing the plugs to the 4 prong and K&N drop in filter...Thoughts?
Old Sep 5, 2010 | 07:51 PM
fv8s's Avatar
Default Re: Just bought a 98 civic HX...
you can possibly get a tune for better mileage, but besides that just basic maintenence will improve your gas mileage
Old Sep 5, 2010 | 07:53 PM
NOFX's Avatar
H-T White Ops
There are some really great forums out there that go over tons of ways to save gas.
A big thing is just in the way you drive it of course.
Try GasSavers.org.
Old Sep 5, 2010 | 08:22 PM
Turbotype's Avatar
Is there anythin specific for the y5 that would benefit it outside of he general things?
Old Sep 5, 2010 | 08:26 PM
Former User's Avatar
Do an ignition system tune up, as already mentioned, and also clean the carbon out of the EGR valve and the ports and passages of the EGR chamber.
Old Sep 5, 2010 | 08:44 PM
Turbotype's Avatar
Default Re: Just bought a 98 civic HX...How maximize MPG?
Carb cleaner would be sufficient to clean the EGR ports right?
Old Sep 5, 2010 | 08:51 PM
Yes, with some vigorous scraping.
Old Sep 5, 2010 | 08:53 PM
Turbotype's Avatar
Like wirebrush scraping? haha...
Old Sep 5, 2010 | 08:56 PM
Yes. Or any other tool that allows you to access and remove carbon build up without damaging the chamber, IM, or valve.
Old Sep 6, 2010 | 02:53 AM
94EG8's Avatar
Seagull Management
If you were thinking about Bosch plugs they work like crap in a Honda. The cheap plain old NGKs will run better than just about anything else.
Old Sep 6, 2010 | 07:03 AM
Meister vtec's Avatar
as 94eg8 already stated the bosch +4 plugs suck ***,your best bet indeed is NGK.
the only things you can really do is run your car with a weight reduction,skinnier and/or lighter wheel combo (if there is any),maintenance,better breathing intake system, a tune with a lean afr for partial throttle,
all that with added with a smart driver could easily add another 4-5mpg to the goverment tested figures.
Old Sep 6, 2010 | 10:21 AM
NOFX's Avatar
H-T White Ops
I have managed to get 42mpg highway with my '98 EX (D16Y8) just by having it in good shape and driving smart.
Old Sep 6, 2010 | 11:38 AM
BlackDeuceCoupe's Avatar
HT White Ops
Yep!
I gotta be the mileage king. I used to get 45-52 MPG with the HX motor. I'm still getting 39-42 MPG in the Si motor...
Driving smart is the largest part of it. Basically, that amounts to keeping your foot out of it (unless you're racing someone), coasting in neutral (on downhills), and don't lug around any extra weight (in the trunk).
Also, I use a K&N panel filter, mix acetone with my fuel (2 ounces per 10 gallons), run copper core plugs, 10W30 Mobil HM (high mileage) motor oil, Red Line MT-90 tranny fluid, and keep my (Pirelli P4) tires pumped up to 40-45 psi.
That's about the size of it.
Old Sep 6, 2010 | 09:07 PM
NOFX's Avatar
H-T White Ops
I've gotten that 42mpg while averaging 80mph. Seems a lot of cars have a sweet spot for mileage aroudn 70-80mph. At least that's in my experience.
Old Sep 8, 2010 | 06:11 AM
Turbotype's Avatar
Originally Posted by BlackDeuceCoupe
Yep!
I'd like to get 40mpg if possible...I shift at 3k rpms and coast when I can and haven't ever floored it lol, seems unnecessary considering its 115hp haha...I ordered a K&N drop in, which should be here today or tomorrow, changed the spark plugs, and am gonna clean out the EGR area this weekend...I don't know what oil type is has right now, but I think its 5W-30...Is there an advantage to going with the HM oil? Car is 126k on it...I think tire pressures are at 35-38...I guess I could goose them up a tad next fill up haha...
Thanks guys for the posts
Old Sep 8, 2010 | 08:07 AM
smetrick's Avatar
I get anywhere from 380-430 miles per tank of gas on my '99 HX with 5spd (about 37 to 41 mpg). I do some stop and go but generally a ten mile commute with half of it on a freeway. Driving habits, inflated tires, and whether or not it's summer are the biggest and cheapest influences on mpg. Someone told me summer blended gas has more BTUs in it.
Old Sep 8, 2010 | 07:12 PM
HT White Ops
Mobil 1 HM has the proper additive package to protect our motors.
Regular Mobil 1 has been reformulated to protect emission equipment in 2006 and newer cars.
If you run regular Mobil 1 in '92-'00 Vics, it will eventually wreck your engine, because most of the additives have been removed.
If you run Mobil 1 HM in '06 and newer Vics, it will wreck your emissions equipment, e.g. kill your cat, et cetera.
Newer motors are designed to run on neutered motor oil. Older motors are designed to run on (so called) HM motor oil.
That's basically the difference...
Old Sep 9, 2010 | 07:02 AM
Turbotype's Avatar
Gotcha, i'll make the switch at the next oil change
Old Sep 9, 2010 | 07:45 AM
Ron454321's Avatar
By newer motors do you mean lower milage? I have a 92 CX with a ZC swap that has about 50,000 miles. Any reason to use HM in there? I've always just used regular oil.
Old Sep 10, 2010 | 12:05 PM
Turbotype's Avatar
What about a hi-flow cat and a lighten flywheel? Would those help fuel economy? What about an intake system over the stock box?
Old Sep 10, 2010 | 01:07 PM
94EG8's Avatar
Seagull Management
HXs are very picky about what you use for a cat, stick with the stock one. lightened flywheel probably wont make much difference either way. If you're going with a short ram you will loose low end power, if its a cold air intake you see minimal gains.
Old Sep 12, 2010 | 02:44 AM
HT White Ops
By 'newer', I meant 'newer' than 2006, e.g. 2006-2011 model years.
And, yes, you should be using HM motor oil, regardless of how many miles you have on your engine. It all about the additive package...
Here's a long post where I explain the whole situation ad naseum: https://honda-tech.com/forums/showpo...3&postcount=11
Matter of fact, I'll just repost it here, to save you some clicking...
Originally Posted by p220guy
I have used mobile 1 full synthetic 5-30 in every one of my cars since day one.
Originally Posted by ALLxMOTOR EG
Mobil 1.
Agreed!
I've used Mobil 1 10W-30 motor oil for years (Red Line MT-90 in my trannies) - and never had an engine/tranny failure!
The thing is...
Mobil 1 has been reformulated several times - and these reformulation(s) have involved protecting emissions equipment - often to the detriment of engine life!
Motor oil (these days) is designed to protect sensitive emissions equipment and increase fuel economy. Engine life has become secondary to oil conservation and clean air!
For instance: Mobil 1 was great in the late 90's, but the 'anti-wear additives' were wrecking cat converters - so, they removed a lot of the zinc, which acts as an extreme pressure (EP) additive. When they removed the zinc, top-fuel race cars started blowing rods and cranks like crazy - every race.
Mobil started adding (an existing) gearbox EP additive to Mobil 1, especially formulated for race cars - and a year later started putting the EP additive in regular Mobil 1. They call this additive "SuperSyn" and it's unique to Mobil 1.
Extra credit reading: http://findarticles.com/p/articles/m...7/ai_85494225/ (BNET Business Library - 2002 SuperSyn Article)
Today, ALL motor oil producers are required (by mandate) to take the 'anti-wear additives' out of regular motor oil, to protect 2006-up emissions equipment - and this ILSAC GF-4 oil is bad for older cars like ours!
Thankfully, Mobil 1 still makes oil designed for older rides. It's called "Mobil 1 High Mileage" - and it has all the 'anti-wear additives' that our rides require, plus the additive package contains chemistry that keeps the internals clean, and stop oil seepage, et cetera.
What do I run??? Mobil 1 High Mileage 10W-30 (and Purolator PureONE oil filters).
If you care about making your motor last DO NOT put ILSAC GF-4 (such as regular Mobil 1 motor oil) in it.
How can you tell the difference between regular Mobil 1 motor oil and M-1 HM???
Old Sep 13, 2010 | 05:47 PM
Ron454321's Avatar
Interesting information, thank you very much.
I was going to seafoam the cranckcase soon and obviously change oil thereafter. Now I know that I will be using HM to replace the regualr oil in there now.
However, do you recommend using a blend first before I switch to synthetic? Never done the switch before, my subie was already running synthetic.
Old Sep 15, 2010 | 07:43 PM
HT White Ops
[...] do you recommend using a blend first before I switch to synthetic? Never done the switch before, my subie was already running synthetic.
No, you don't have to run a blend -- or flush out the old oil, et cetera.
The problem is when you switch from one brand of synthetic oil to another. Everyone uses different chemistry. In that case, you would want to switch to dino oil for one change. Then, use the new synthetic after the next drain.
Put another way, you DO NOT want to mix different brands of synthetic oil together...
my daughters
Aug 12, 2015 02:09 AM
leflore
Honda Civic (2006 - 2015)
May 8, 2014 11:50 AM
prrprr
14
Oct 5, 2012 01:44 AM
rmd0311
Apr 8, 2008 12:41 PM
makri
16
Dec 19, 2005 07:04 PM
