Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Overview
- How to Maximize Your MPG
Step by step instructions for do-it-yourself repairs
Just bought a 98 civic HX...How maximize MPG?
and I have some questions about it....First off, it's the D16y5, which is the econ vtec motor...I'm looking for ideas on what I can do to maximize my MPG...I already plan on changing the plugs to the 4 prong and K&N drop in filter...Thoughts?
H-T White Ops
Re: Just bought a 98 civic HX...
There are some really great forums out there that go over tons of ways to save gas.
A big thing is just in the way you drive it of course.
Try GasSavers.org.
Try GasSavers.org.
Do an ignition system tune up, as already mentioned, and also clean the carbon out of the EGR valve and the ports and passages of the EGR chamber.
Re: Just bought a 98 civic HX...How maximize MPG?
as 94eg8 already stated the bosch +4 plugs suck ***,your best bet indeed is NGK.
the only things you can really do is run your car with a weight reduction,skinnier and/or lighter wheel combo (if there is any),maintenance,better breathing intake system, a tune with a lean afr for partial throttle,
all that with added with a smart driver could easily add another 4-5mpg to the goverment tested figures.
HT White Ops
I gotta be the mileage king. I used to get 45-52 MPG with the HX motor. I'm still getting 39-42 MPG in the Si motor...
Driving smart is the largest part of it. Basically, that amounts to keeping your foot out of it (unless you're racing someone), coasting in neutral (on downhills), and don't lug around any extra weight (in the trunk).
Also, I use a K&N panel filter, mix acetone with my fuel (2 ounces per 10 gallons), run copper core plugs, 10W30 Mobil HM (high mileage) motor oil, Red Line MT-90 tranny fluid, and keep my (Pirelli P4) tires pumped up to 40-45 psi.
That's about the size of it.
H-T White Ops
I've gotten that 42mpg while averaging 80mph. Seems a lot of cars have a sweet spot for mileage aroudn 70-80mph. At least that's in my experience.
Yep!
Thanks guys for the posts
I get anywhere from 380-430 miles per tank of gas on my '99 HX with 5spd (about 37 to 41 mpg). I do some stop and go but generally a ten mile commute with half of it on a freeway. Driving habits, inflated tires, and whether or not it's summer are the biggest and cheapest influences on mpg. Someone told me summer blended gas has more BTUs in it.
HT White Ops
Mobil 1 HM has the proper additive package to protect our motors.
Regular Mobil 1 has been reformulated to protect emission equipment in 2006 and newer cars.
If you run regular Mobil 1 in '92-'00 Vics, it will eventually wreck your engine, because most of the additives have been removed.
If you run Mobil 1 HM in '06 and newer Vics, it will wreck your emissions equipment, e.g. kill your cat, et cetera.
Newer motors are designed to run on neutered motor oil. Older motors are designed to run on (so called) HM motor oil.
That's basically the difference...
What about a hi-flow cat and a lighten flywheel? Would those help fuel economy? What about an intake system over the stock box?
Seagull Management
HXs are very picky about what you use for a cat, stick with the stock one. lightened flywheel probably wont make much difference either way. If you're going with a short ram you will loose low end power, if its a cold air intake you see minimal gains.
HT White Ops
And, yes, you should be using HM motor oil, regardless of how many miles you have on your engine. It all about the additive package...
Here's a long post where I explain the whole situation ad naseum: https://honda-tech.com/forums/showpo...3&postcount=11
Matter of fact, I'll just repost it here, to save you some clicking...
I've used Mobil 1 10W-30 motor oil for years (Red Line MT-90 in my trannies) - and never had an engine/tranny failure!
The thing is...
Mobil 1 has been reformulated several times - and these reformulation(s) have involved protecting emissions equipment - often to the detriment of engine life!
Motor oil (these days) is designed to protect sensitive emissions equipment and increase fuel economy. Engine life has become secondary to oil conservation and clean air!
For instance: Mobil 1 was great in the late 90's, but the 'anti-wear additives' were wrecking cat converters - so, they removed a lot of the zinc, which acts as an extreme pressure (EP) additive. When they removed the zinc, top-fuel race cars started blowing rods and cranks like crazy - every race.
Mobil started adding (an existing) gearbox EP additive to Mobil 1, especially formulated for race cars - and a year later started putting the EP additive in regular Mobil 1. They call this additive "SuperSyn" and it's unique to Mobil 1.
Extra credit reading: http://findarticles.com/p/articles/m...7/ai_85494225/ (BNET Business Library - 2002 SuperSyn Article)
Today, ALL motor oil producers are required (by mandate) to take the 'anti-wear additives' out of regular motor oil, to protect 2006-up emissions equipment - and this ILSAC GF-4 oil is bad for older cars like ours!
Thankfully, Mobil 1 still makes oil designed for older rides. It's called "Mobil 1 High Mileage" - and it has all the 'anti-wear additives' that our rides require, plus the additive package contains chemistry that keeps the internals clean, and stop oil seepage, et cetera.
What do I run??? Mobil 1 High Mileage 10W-30 (and Purolator PureONE oil filters).
If you care about making your motor last DO NOT put ILSAC GF-4 (such as regular Mobil 1 motor oil) in it.
How can you tell the difference between regular Mobil 1 motor oil and M-1 HM???
Interesting information, thank you very much.
I was going to seafoam the cranckcase soon and obviously change oil thereafter. Now I know that I will be using HM to replace the regualr oil in there now.
However, do you recommend using a blend first before I switch to synthetic? Never done the switch before, my subie was already running synthetic.
HT White Ops
The problem is when you switch from one brand of synthetic oil to another. Everyone uses different chemistry. In that case, you would want to switch to dino oil for one change. Then, use the new synthetic after the next drain.
Put another way, you DO NOT want to mix different brands of synthetic oil together...
my daughters
08-12-2015 02:09 AM
