Knock Sensor Problem
I just got a 2000 civic EX. The engine was bad so I rebuilt it, but when I was taking it apart I noticed that the plastic part of the knock sensor was hanging with the harness. Ok, so now I have a knock sensor broken in half. Anyway I finished the engine it runs smoothly, but the only thing is that obviously I have the knock sensor circuit code and I think that my PCM is retarding my timing cause of it.
Is there's anyway to cancel that sensor or bypass it. They want around $135 for it dam!!!
Any help would be much appreciated
Thanks
Thanks
I recently got one from the market place for $69.99 shipped, the sensor was made by omnipowerusa it works fine
https://honda-tech.com/forums/performance-45/new-honda-acura-knock-sensor-replacements-2702876/
1. Boost is not mentioned in the original post.
2. Were boost an option, the P28 doesn't help anyway.
3. The cost of a jumper and a P28 would exceed the cost of a replacement sensor.
2. What do you mean? It's the perfect ECU to chip and boost with and it DOESN'T LOOK FOR A KNOCK SENSOR.
3. Maybe he means that $135 is too much for a knock sensor, you don't know how much more he has.
BEATurBOYS
Dec 18, 2009 07:16 PM
