B16 increase VE above 5500rpm?
Old Aug 1, 2010 | 06:43 AM
mrx's Avatar
mrx
Default B16 increase VE above 5500rpm?
Hallo,
i've a complete stock B16 (stock head, stock cam's) with a GT28RS turbo and an equal length manifold on.
What can i do (best bang for the $) to improve my VE above 5500rpm till 8500-8600rpm.
i don't want to extend the redline further, so i don't need things that will work till 20k ;-)
hope someone can give me some hints... would be best to see any dyno prooved things but i take any advice too.
Old Aug 1, 2010 | 06:59 AM
HPTautosport's Avatar
Default Re: B16 increase VE above 5500rpm?
Port the head, oversize valves, buy a nice IM and portmatch it, bigger tb, cams.
Old Aug 1, 2010 | 07:06 AM
mrx's Avatar
mrx
by the way, is it normal that a stock b16 begin to loose VE above 6600rpm. Because thats what i've experience with mine.
Old Aug 1, 2010 | 08:25 AM
tony413's Avatar
your probably maxing out the turbo
Old Aug 1, 2010 | 09:49 AM
vwbased's Avatar
have a nice day
Old Aug 1, 2010 | 12:17 PM
mrx's Avatar
mrx
i don't think it's the turbo.
Because it's at almost every boost level
and the compressor outlet temps are withing reason, so no fall out of the efficiency range.
Maybe backpressure pre-turbine, but if so, the effect should get worse with higher boost, which is not the case.
I'am also currently far below 350hp, so the compressor should be big enough... turbine is already the .82ar T3 housing with an external WG
Old Aug 1, 2010 | 03:15 PM
tony413's Avatar
can you post up a dyno? or some logs?
CRXherbie91
Mar 3, 2011 08:00 PM
hpc.aeroe.
Dec 18, 2008 11:46 AM
joethejoeman
Jul 24, 2007 08:54 PM
The sweed
Mar 6, 2007 10:34 AM
jonezen1
Aug 18, 2006 06:03 PM
