need help, CEL
Old May 14, 2010 | 10:01 AM
jakl's Avatar
Default need help, CEL
i tried checking my CEL on my del sol but its not working :/
1995 Del Sol
Fresh Swapped JDM B18C
JDM p72
OBD1
the plug that i jumped was blue with a black and brown wire. when i turn the key the CEL light goes on, then either turns off (like it reset the CEL) or stays solid. Any suggestions??
Old May 14, 2010 | 10:03 AM
Former User's Avatar
Default Re: need help, CEL
Without the service connector jumped, does the CEL remain on solid with the key in ON(II)?
Have you checked whether the 7.5A hood Back Up fuse is blown?
Old May 14, 2010 | 10:08 AM
jakl's Avatar
ill go check the fuse real quick. but without it jumped it either stays solid or turns off as well (like it reset). once i drive the car for like 1 minute, it pops back on.
Old May 14, 2010 | 10:14 AM
jakl's Avatar
k, so it was blown and i replaced it and tried to get the codes but the same results :/ stayed solid
Old May 14, 2010 | 10:23 AM
Check whether the fuse blew again.
To pull 5th gen codes, sometimes you must wait for the CEL to turn on, and then pull over and leave the engine running while you jump the service connector. Try this.
Old May 14, 2010 | 10:25 AM
jakl's Avatar
fuse is still good. lemme try that
By the way, one common cause for a blown 7.5A Back Up fuse is a short in the Wht/Blu wire at the rear of the radio.
Old May 14, 2010 | 10:27 AM
jakl's Avatar
worked code 14, iacv
Old May 14, 2010 | 10:29 AM
Clean the IACV and, if the code still pops, then check the IACV wires. Any idle problems?
Old May 14, 2010 | 10:33 AM
jakl's Avatar
there is no problem with idle, maybe a tad too high at 1100-1200 (i think normal is 700-1000?). the problem is the car wants to bog out when the gas is pressed. it seems to only do so when the car is a normal temp, but i havent confirmed it.
Old May 14, 2010 | 10:39 AM
You idle is too high. It should be about 700 rpm. Clean the IACV and check the wires.
The bogging is a separate problem. How old are the plugs, wires, cap, and rotor? Is the ignition timing set to spec?
Old May 14, 2010 | 11:38 AM
jakl's Avatar
i cleaned it and its the same problem. the whole harness is from my old b16a, which had no CELS. a few of the sensors were a bit trashed and i spliced new ones on. i dont think this one was one of em. the distributor(not that it matters, i dont think), cap, and rotor are the ones from my b16 and are only about 2 months old. everything in tact and in good shape still. as for the timing i dont know much of. i played with it a bit but didnt seem to help no matter what position it was in. after the cleaning. i reset the codes and it popped up the same on again.
wolf95
21
Jul 31, 2009 11:11 PM
DesiDez
Oct 20, 2007 09:07 AM
sedativ_02
Sep 8, 2006 02:26 PM
ragnaroek
11
Jul 26, 2005 05:33 AM
