2.0 fully built gsr break in
break in procedure i recomend keeping the wastegate open, remove intercooler piping and breaking in the motor NA.
let me give you a link as to what i recommend for a break in procedure...
http://cccylinderheads.com/main.html
click tech, then click 85x89 build
follow his break-in procedure. break-in's should last roughly 1 hour. seriously
honestly there are so many ways of breaking in a car. some people take it easy. some put it right on the dyno. There really is no specific way of doing it. I recommend starting it up. hold at a steady 2000/2500 rpm for a lil. shut off. make sure everything is ok. change the oil. no metal shavings. just go out and drive it around. etc etc. after a couple miles its pretty much good to go man.
yep, a buddy of mine build his motor and drove it to the dyno, changed the oil right before and that was it. The first 20 miles really is all that matters. but like ef91 says, there are alot of different ways to do it.
Boostinb20!
Jun 4, 2009 08:15 AM
BodyKits NW
Sep 16, 2007 03:23 PM
