Car wants to stall sometimes and Loss of power
So recently my car [99 dx d16y7 5spd] has been acting weird, It drives fine but when the car warms up good it begins to want to stall at idle but it doesnt, the lights dim but when i give it gas its all good [at idle] , when i begin driving there is a loss of power for a couple of seconds or until i give it more gas.
I replaced the fuel filter and it still does the same. After the car acts up i begin driving and feel the loss of power. After I drive like this for a few minutes, it stops acting up. Im beginning to look at the alternator but I want to know what ya think.
Thanks
Thanks
is your cel shooting any codes? did you change your spark plugs, wires, rotor, distributor cap? if you are shooting any codes, try and fix those problems first. if it still occurs then change those parts listed above. check your fuel pressure too.. i've had a similar problem last week and my cel was shooting ignition coil and knock sensor so i changed the ignition coil and i re-wired my knock sensor correctly and it eliminated the problem.
speed sensor will not rob power unless your motor has vtec (then it won't engage), and o2 sensor can definitely cause a loss of power, loss of mpg, and some claim a wierd odor from exhaust. i'd check your wiring and if that seems good then change your o2 sensor. see if that fixes your problem first before you move on to checking other things. there are a lot of different things that can cause the problem you have so it's just a matter of trying to figure out which one it actually is without changing out things that don't need to be touched.
just a list of some things that i would check:
plugs
wires
rotor
dis. cap
ignition coil
timing
o2 sensor ***
knock sensor
fuel filter
fuel pump
injectors
plugs
wires
rotor
dis. cap
ignition coil
timing
o2 sensor ***
knock sensor
fuel filter
fuel pump
injectors
Thanks
Thanks
check your spark plugs and let us know how burnt they are. i'm guessing, cracked exhaust manifold + air goes through the crack = running RICH which = all the symptoms you have (and me 2)
soo i replaced the spark wires and it ran fine for about half an hour til i got home. Now i got off work and it began doing it again. If i rev the car and pop the clutch it runs fine and runs fine from then on. But the idle is still rough. Im thinking its the distributor.
Ehop
11
Feb 11, 2008 10:09 AM
90_Si
Sep 13, 2007 02:45 PM
