d15b compression results- 180-165-165-160 this good?
So i bought a 95 civic with a blown head gasket and i wanted to check the compression before i did all the work to fix it and these are the results:
Cylinder #1- 180psi, #2- 165psi, #3- 165psi, and #4- 160psi. Is this good or not??
Thanks for the help
Thanks for the help
Well the head gasket is blown at the moment. What is the compression suppose to be on the d15b?
Also the oil has coolant in it too.
I thought if the compression is lower then 120psi or the cylinders have more then a 25% difference in psi then i should start worrying.
theres a high limit too, which is at ~175 psi for Ds
you may have carbon build up in cyl 1 that makes it raise comp
also specs say there shouldnt be 28psi difference in no two cylinders, your in spec for that
how did you do your test was the engine fully warmed and at WOT? This is the correct way, my D15b JDM got all within a few psi of 205.
OP, those last 3 numbers are kind of low for (assuming) the lowish miles on that motor. They are within spec, but hopefully they come up after you replace the HG.
The car actually has alittle over 150000 on it and the head and tranny has been replaced but the block hasnt been touched since the pervious onwer has had it and hes owned it for 6 years(he bought it from the original onwer).
must do a compression check when the engine is cold to the touch only. when the motor is warm u will get high inaccurate numbers
Boostn B20
11
Nov 27, 2008 01:22 PM
MLogan
May 22, 2003 01:09 PM
