Compression ratio???
Old Mar 17, 2003 | 06:58 PM
aut0tek's Avatar
Default Compression ratio???
Okay, what would be a way to check my compression ratio when my head is milled around 35-40 thousandths?
My headgasket is .067" thick... yea. big. lol.
LS/VTEC B16a head with JE 5.7 dome pistons...
I did a compression test and they were around 225, which would be correct compression for say... 10.3:1 but I'm not sure if that would be a good way to see what my compression ratio is.
Thanks.
Harry
Old Mar 17, 2003 | 07:36 PM
TimoneX's Avatar
New User
Default Re: Compression ratio??? (aut0tek)
I got 11.25:1. Interestingly your thick head gasket is canceling out any gains from your milling almost perfectly. Cylinder pressure w/ a gauge will lie, due to the effect of the compression lost through valves opening and closing.
Old Mar 17, 2003 | 07:50 PM
aut0tek's Avatar
Default Re: Compression ratio??? (TimoneX)
Cool.. Thanks. I've been looking around FOREVER for the mathematics to accurately account for head milling... can u post the equations for that?
Thanks.
Harry
Old Mar 17, 2003 | 08:01 PM
TimoneX's Avatar
New User
Didn't do any math...too lazy. I used C-speed's compression calculatricia, subtracted your head milling from your gasket thicknes, and used your dome displacement spec. Probably not precise, but it'll be close.
Old Mar 18, 2003 | 12:16 AM
aut0tek's Avatar
Oh ok... I actually think I found a formula... it's some long thing that takes your bore, your milling, and pi divided by 4 and I dunno. lol. It came up to 11.1 so you were definitely close enough for government work. lol.
Harry
Old Mar 18, 2003 | 11:00 AM
TimoneX's Avatar
New User
The only way to be precise is to cc the combustion chambers and plug that into the formula. Even using equations w/o measuring exactly what space there is will be +/- a few tenths. Close enough for most purposes.
EG type GTR
Aug 13, 2006 09:05 AM
d.n.d.
Jul 17, 2005 08:39 AM
