Hesitation/Miss seems to be getting worse, need help
Old Sep 7, 2002 | 12:05 PM
pelotudo's Avatar
Default Hesitation/Miss seems to be getting worse, need help
Since I got the ZC I have had a slight miss/hesitation. I adjusted a few things and tightened a few motor mounts and the hesitation went away. The slight miss was still there though.
I installed the Greddy kit along w/ a MSD 6A, modded cap, Accel coil, new NGK BKR6E-11's, adjusted timing (-2degrees from stock), replaced fuel filter, hooked up FMU, and so on.
It seems to be getting worse now. It's just a total lack of power when a semi throttle. If I go WOT, it will jump a little and take off. I am getting all kinds of small backfires out the muffler when off the throttle or just barely touching it.
Does anyone have any idea what this could be? My a/f sways in the stoich/little bit in to the lean when cruising, and goes to rich @ WOT when the FMU kicks in.. It's getting aggrivating...
I checked the vacuum lines, but can't seem to find anything wrong. Does anyone have this diagram again, and I'll double check again to make sure.
jB
97grnrs
Jan 21, 2007 02:49 PM
BIG RICH
Oct 1, 2006 09:54 AM
BoostedB16EF8
Jan 26, 2004 03:52 PM
redzcstandardhatch
Dec 21, 2002 11:19 AM
uneekcrx
Apr 8, 2002 08:31 AM
