Cylinder #2 wall is scratched
Old Feb 25, 2010 | 11:09 PM
airmaxbri's Avatar
Default Cylinder #2 wall is scratched
I recently bought a LS block with a fresh hone.
When my builder was building the block, he said there was a small scratch in cylinder #2 . He said it's deep enough that you can feel scratch with his fingernail.
He said the cylinder would still pass a leakdown test, but he also said that the compression would be affected in that cylinder, but he did not know by how much.
Has this every happened to anyone before?
If so, how bad was your compression/leakdown effected?
My build is a P30'd Lsvtec, PnP b16 head, skunk2 pro2's blah blah blah.
thx
B
Old Feb 26, 2010 | 04:19 AM
AllmotorGSReg's Avatar
Default Re: Cylinder #2 wall is scratched
if you can feel the scratch then you need a bore!
Old Feb 26, 2010 | 04:46 AM
airmaxbri's Avatar
What would happen if I just ran it?
Old Feb 26, 2010 | 06:34 AM
Meister vtec's Avatar
well it all depends on how much loss in compression the so called scratch robbs from you, the more the comp loss the more the power loss but we obviously cant estimate
you would be much more happier with a fresh bore and 82mm pistons IMO and if that doesnt take care of it, then you need a new ls block which can be found for cheap anyway.
Old Feb 26, 2010 | 06:39 AM
4piston's Avatar
thx
B
Just get an oversized piston and fix the problem. You know the right way to do it, and the right way is the only way every time.
Old Feb 26, 2010 | 06:59 AM
95 integra's Avatar
Buy a new LS block or bore it over.....no reason not to at this point. Why chance poor power and burning through oil when you could easily and cheaply fix the problem now?>
Old Feb 26, 2010 | 07:06 AM
tobster's Avatar
buy another block they are like 50.00 dude
Old Feb 27, 2010 | 05:44 AM
if its at stock bore right now just bore it out to 81.5mm, if you run it with the scratch you could lose compression plus oil will blow by and it could smoke too.
Old Feb 27, 2010 | 09:44 AM
h2.4's Avatar
Couldn't have been any more right. Spoken with experience and knowledge.
Old Feb 28, 2010 | 05:54 PM
airmaxbri's Avatar
Where do you get them for that much?
I'll take 10 of them. LOL.
Em1Dustin
Jun 4, 2019 08:32 PM
airmaxbri
Feb 27, 2010 10:34 AM
FinedTuned
Jun 13, 2009 05:09 PM
aznxpyroboi
Dec 9, 2007 10:09 PM
