Compression Test Results!!
Old Jun 13, 2009 | 02:08 PM
FinedTuned's Avatar
Default Compression Test Results!!
I just did a compression test on my Ls and I wanted to see if this engine can handle turbo. So here are the numbers.
Cylinder 1: 190
Cylinder 2: 165
Cylinder 3: 165
Cylinder 4: 195
So do guys think is still good enough to run turbo. Let me know. Thanks
Old Jun 13, 2009 | 02:13 PM
98vtec's Avatar
moderator emeritus
Default Re: Compression Test Results!!
i would probably replace the headgasket.
Old Jun 13, 2009 | 02:49 PM
tw1tch's Avatar
Cylinder 1: 190
Cylinder 2: 165
Cylinder 3: 165
Cylinder 4: 195
2 and 3 don't look so hot. I'd get new rings and valve seals at the least. Doing a rebuild now will be much easier than boosting and throwing a rod thru the block. The Ls has 199 compression from the factory. You want the cylinders to wear evenly, and yours are off a bit. Full or partial rebuild and you should be all good.
Old Jun 13, 2009 | 05:09 PM
sucka4eg's Avatar
Boost it, blow it up, get a new one. =D they're a dime a dozen.
02BladeRider
Jul 7, 2017 05:49 AM
carlos8
Aug 2, 2016 02:57 PM
91EF919
18
Aug 4, 2009 12:50 PM
aznxpyroboi
Dec 9, 2007 10:09 PM
dreamreaperx
Dec 20, 2006 02:01 PM
