Having trouble starting new motor....
Old Sep 6, 2002 | 09:23 PM
Projekt20's Avatar
Default Having trouble starting new motor....
I'm pretty sure I have everything hooked up....but I can't get my newly rebuilt motor to turn over. Any ideas? Thanks!
-Trung
Old Sep 6, 2002 | 09:31 PM
paulzy's Avatar
Default Re: Having trouble starting new motor.... (Projekt20)
what's it doing? cranking? not cranking?
Old Sep 6, 2002 | 09:32 PM
HybridKOOP's Avatar
Battery, ECU, distributor, wires, spark plugs, fuel pump, injectors, regulator, MAP sensor, IACV sensor, gas in the tank...
Wow I am *drunk*. I think my checklist makes sense, don't it?
Old Sep 6, 2002 | 09:34 PM
bretx0r's Avatar
starter bad? check ecu harness
Old Sep 6, 2002 | 09:35 PM
Projekt20's Avatar
Default Re: Having trouble starting new motor.... (paul_vang)
It cranks....but it just won't turn over. I know fuel is getting in there cause I smell a hint of it in the bay. No spark maybe? Louis have a few shots of 99 Bananas on me and go 2 sleep.
-Trung
Old Sep 6, 2002 | 09:41 PM
HybridKOOP's Avatar
ZzZzZZZzZZzzzZzz.....
Old Sep 6, 2002 | 10:32 PM
IntegD's Avatar
New User
Just pull a plug wire off the end of the cap and hold it like an inch away and see if you are getting spark. If you are, then that could be a compression problem. Just break out the gauge if you are getting spark, if not, try to figure out why you arent firing. Good luck
Old Sep 6, 2002 | 11:12 PM
Projekt20's Avatar
Default Re: Having trouble starting new motor.... (IntegD)
Yep....no spark. Getting fustrated.
DC2R96
Mar 14, 2011 04:41 PM
Bo0steDC4
Oct 10, 2008 02:31 PM
pchris52
Apr 17, 2006 04:00 PM
asmallsol
Feb 27, 2004 02:43 PM
boostaholic
Jul 2, 2002 08:49 PM
