GT37R versus GT3788R
Old Jan 22, 2010 | 02:40 PM
rudebwoy's Avatar
Default GT37R versus GT3788R
searching turbos and want to see which one is bigger and better, I am not sure if they are the exact turbos, I currently have a t3/t67 and I wanna change to something ball bearing, but wanna keep same size or bigger in a t3 flange.
Old Jan 22, 2010 | 05:00 PM
2.0L_of_fun's Avatar
Default Re: GT37R versus GT3788R
if it'is becaue of your manifold. just sell it and buy one with the flange you need!!!
Old Jan 22, 2010 | 05:36 PM
96 GSR-T's Avatar
Full-Race calls a Ball Bearing T3/T67ho a GT37R.... in T3 form they can make 700-750hp depending on the dyno..... I am selling one right now that only has one pass on it.
The GT3788R has the same Comp wheel as a GT40R but with a smaller Turbine wheel, Garrett rates it at 675hp.... and as far as I know its divided T4 only
Old Jan 22, 2010 | 06:14 PM
Turbo-LS's Avatar
From what iuve gathered the gt37 is more of a diesel application and the wheel combinations dont work as well as a better thought out turbo system. thats what ive read and got from dealers.
the t3/t67ho is where its at IMO. the ball bearing is only going to give you a little better spool its more respool thats effected by ballbearing turbos. Alot of peopel are going with precisions new 6265 billet and making t67 power and they are offered in bb
Old Jan 22, 2010 | 06:33 PM
TheShodan's Avatar
Moderator
Unfortunately, many tests and feedback over the years have showed that there was no increased "spool" between the 2 versions.
Old Jan 22, 2010 | 06:43 PM
96 GSR-T's Avatar
Thats odd, why did my 8.2:1 GSR cammed 1.8L with a BB 67ho outspool my friends 9.5:1 true 2.0L with a journal 67 stg5 wheel by a good 500rpm? The rest of the setup was identical........ not a true back to back test but it has to mean something.
Wouldnt the rather large increase in displacement, higher compression and slightly smaller turbine wheel help spool alot?
Old Jan 23, 2010 | 12:36 PM
rudebwoy's Avatar
no need for a t4 manifold on a street car, the t3 frame is enough for now.
quote:Turbo-LS
I will never again use any turbos touched by precision, bad experience shitty customer service.
quote:96 GSR-T
thanks that answered my question.
to all my only reason for searcing this turbo is not for a quicker spool up, its only because I want a more reliable turbo that will withstand the long autobahn drives, water cooled, better oiling, therefore ball bearing. my t67 is burning a little oil and some play.
Old Jan 23, 2010 | 02:13 PM
TheShodan's Avatar
Moderator
And you were using the exact same amount of pressure for each car?. To answer your other question. 1) No. the stage 5 and P-trim don't affect "spool" as much as top end power.. even then, the differences are slight. 2) 1.8 vs. 2.0 litre looks more at torque than power (if he is a true 2.0 litre--many mistaken an 84mm GS-R as a 2.0 litre.) 3) the higher compression helps with TRANSIENT response off-boost between gears. There were other factors than "spool" that were at work with your example here.
Old Jan 23, 2010 | 02:31 PM
96 GSR-T's Avatar
Yes same boost pressure..... 21-23psi
1) but there is a difference correct?
2) 85x89 is a true 2.0L, so your saying increasing displacement does not decrease spool time?
3) higher compression increases power off boost and responce and shouldnt that equate to "coming into boost" a little faster?
IDK what other factors you mean....... it dont really matter but if you want to continue please feel free to pm me.
Old Jan 23, 2010 | 07:38 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
manifold type and exhaust setup would come into play.
Old Jan 23, 2010 | 08:49 PM
96 GSR-T's Avatar
I already stated everything else was the same, both had matching ramhorns and 3" DP's w/ 3" Thermal Exhausts....lol
Old Jan 24, 2010 | 11:40 AM
rudebwoy's Avatar
my t3/t67 journal bearing turbo spools real fast on a 2.0l motor, spool up time it over rated for bb turbos. but from what I've between shift response is where a bb performed, plus its more reliable. I launch at 6500rpm so thats way above spool time, does not matter.
SD-ek
Sep 29, 2011 04:10 PM
reactiondc2
Oct 5, 2007 07:33 PM
integraboosted
Dec 26, 2005 01:06 AM
IGotVTECyo
Oct 24, 2005 01:06 AM
mrbsponge
Nov 17, 2004 04:43 PM
